how to use bootstrap to calculate P value???
i just got how to perform bootstrap command but I didnt figure out how to generate the P value using igor pro.
any suggestion will be helpful.
thank you.
The Bootstrap is a very large topic, and since Igor doesn't have a built-in bootstrap you must be coding it yourself, or using someone else's code. Generating a p value no doubt depends on what you are doing.
The classic book on the topic is Efron, B. & Tibshirani, R. J. (1993). An introduction to the bootstrap. London: Chapman & Hall/CRC
