New book about programming Igor
For quite a while, there was no book about Igor programming and it was hard for my students to reach a certain level.
I got the feeling that many people actually had problems with programming Igor and so I decided to write a little book about it.
It is now available on Amazon.
I tried to write the book from a more general perspective (I used C/C++ and Python in the past) and discussed things like code encapsulation, graphical user interfaces, or regular expressions on a beginners level (some people are completely unaware that Igor even supports concepts like regular expressions and the like).
And several new (and nice) features of Igor 7 are mentioned as well.
Great! I just ordered a copy. Hoping it will get more people in my lab programming in Igor.
Wonderful to see such a resource in print!
I too have order a copy and look forward to it.
Maybe we should form a book club ;)
Thanks for the positive feedback! It is actually really nice to see that the community cares!
It is a good read for the Igor beginner, I've skimmed through the book last weekend.
@MSchimd: I've sent my longer feedback to the email provided in the book.
I got the book and read it over the weekend. Very nice. I even learned/appreciated a thing or two.
I will provide some additional feedback directly.
I think there is an opportunity to have a discussion as how to teach getting the most out of Igor Pro when the target user is most likely a scientist/engineer as their day job and need a tool to get things done. This is in contrast to programmers as the primary audience for some other programs/languages.
The hybrid interface is a unique feature which I use often in doing ad hoc analysis. Also I find myself creating a user interface even for myself when I am exploring data, something again Igor Pro does so very well. So I think there may be common workflows that could act as teaching method to bring the new user up the learning curve faster.
Dear Igor users,
I updated the book when Igor 8 was released and included another example that shows how to do a curve fit with a neural network. Because I think neural networks are awesome, I list this example below, so that also everyone with an older version of the book can see it.
Run this module with
  1. NeuNet#teach(150)
  2. NeuNet#run()
  3. NeuNet#show()
  4. Several times more NeuNet#run() to play around a bit
The parameter 150 is the number of training sets for the NN which works best. Note that getting the number of training sets and learning rate right can be a bit finicky. Play around yourself.
#pragma moduleName = NeuNet
static constant N =70
static constant low = 0
static constant high = 1
static constant width = 0.01
static function teach(M)
    variable M              // number of parameter sets for training
    variable i
    make /o/d/n=(M,2) TrainingParameters
    wave par = TrainingParameters
    // for simplicity, use random parameters in a reasonable range
    // first column: amplitude
    // second column: position
    // then, each row contains a full parameter set
    par[][0]=0.1 + 0.8*(0.5+enoise(0.5))                //[0.1 ; 0.9]
    par[][1]=0.5 + enoise(0.45)                 //[0.05 ; 0.95]
    // generate the curves of the training parameters
    make /o/d/n=(M,N) TrainingCurves
    wave tc = TrainingCurves
    SetScale /I y, low, high, tc            // note the normalization to [0,1]
    // store them in rows, not in columns
    for (i=0; i<M; i+=1)
        tc[i][] = par[i][0]*exp(-(y-par[i][1])^2/width)
    //now the neural network will learn the
    //connection between parameters and curveshape
    NeuralNetworkTrain nhidden=50, input=tc ,output=par
    // the result of this learning process will be saved in two
    // waves M_weights1 and M_weights2
    // these waves contain all the necessary information for running the network
static function run()
    // make an arbitrary test curve
    make /o/d/n=(N) sampleWave            // number of points has to be the same as
        // in the training set!
    wave sW = sampleWave
    SetScale /I x,low,high, sW
    // neural networks are better with interpolating rather then extrapolating:
    // use smaller ranges than in the training set
    variable randomHeight = 0.2 + 0.6*(0.5+enoise(0.5))     //[0.2 ; 0.8]
    variable randomLoc = 0.5 + enoise(0.25)             //[0.25 ; 0.75]
    sW = randomHeight*exp(-(x-randomLoc)^2/width)
    sw += gnoise(0.01)
    // make references to the output waves of the training session
    wave W1 = M_weights1
    wave W2 = M_weights2
    // run the neural network
    NeuralNetworkRun input=sW, weightsWave1=W1, weightsWave2=W2
    // draw the result
    // the wave W_NNResults is automatically created by the neural network
    wave NNRes = W_NNResults
    make /D /O /N=(N) NNCurve
    wave NNC = NNCurve
    SetScale /I x,low, high, NNC
    NNC = NNRes[0]*exp(-(x-NNRes[1])^2/width)
static function show()
    // call this function only after NeuNet#run() was active at least once
    // so all waves are actually there
    wave NNC = NNCurve
    Display sW
    AppendToGraph NNC
