areaxy
I'm trying to figure out how to use the areaxy function to generate a list of values between a single x-series (time) and 1,000 different y-series. I only have 6 time points and a corresponding number of y-values. Using the print areaxy command, I can get the area values, however, I don't want to manually do this 1,000 times. How can I import the data sets from Excel into Igor, have it automatically calculate the areas and generate a new wave containing those values? Can anybody help.
Mark
I have posted a snippet that does the area work here. Copy and paste it to your procedure window. Read the comments to see how it works. You will need to find a way to come up with a list of your 1000 Y wave names. If they are named systematically then you can use WaveList as shown in the example.
You can load Excel data using the XLLoadWave operation. Execute this:
DisplayHelpTopic "XLLoadWave XOP"
For a discussion of loading multiple waves from a user-defined function:
DisplayHelpTopic "Loading Waves Using Igor Procedures"
You will have to modify the procedures shown there to use XLLoadWave instead of the LoadWave operation and will no doubt need to make other modifications.
[Mark has a table where column 0 is a wave containing x values, and the other columns (about 500 of them) contain Y values. He want the average of those Y values using the X wave to provide X coordinates, all of those averages in one wave.]
Here's the macro and function I came up with:
Macro AreaXYOfTableXinFirstCol(outputWaveName, showResultInTable)
    String outputWaveName="AreaOut"
    Variable showResultInTable= 1   // 1 == yes, 2 == No
    Prompt outputWaveName, "Choose name for output wave:"
    Prompt showResultInTable, "Show result in new table?",popup,"Yes;No;"
    String tableName= WinName(0,2)
    if( strlen(tableName) == 0 )
        DoAlert 0, "Expected a table to read waves from"
        return
    String pathToWave= fAreaXYOfTable(tableName,outputWaveName)
    if( strlen(pathToWave) && showResultInTable == 1 )
        Edit $pathToWave
Function/S fAreaXYOfTable(tableName,outputWaveName)
    String tableName,outputWaveName
    WAVE/Z wx= WaveRefIndexed("Table0",0,1)     // first wave contains X values
    if( !WaveExists(wx) )
        DoAlert 0, "Expected wave in first column of table "+tableName
        return ""   // failure
    // Figure out how many other waves are in the table
    String ListOfAllWaves= WaveList("*", ";", "WIN:"+tableName)
    Variable numOfYWaves= ItemsInList(ListOfAllWaves) -1
    if( numOfYWaves < 1 )
        DoAlert 0, "Expected wave in second and following columns of table "+tableName
    WAVE output= $outputWaveName
    if( WaveExists(output) )
        DoAlert 1, "Wave "+outputWaveName+" exists. Overwrite?"
        if( V_Flag != 1 )
            return GetWavesDataFolder(output,2)
    Make/O/N=(numOfYWaves) $outputWaveName
    Variable index= 1   // skip 0, that's X
    do
        WAVE/Z wy= WaveRefIndexed("Table0",index,1)
        if( !WaveExists(wy) )
            DoAlert 0, "Expected wave in column "+num2istr(index)+" of table "+tableName
            break
        if( WaveType(wy,1) != 1 )
            DoAlert 0, "Expected numeric wave in column "+num2istr(index)+" of table "+tableName
            break
        Variable theArea=areaxy(wx,wy)
        output[index-1] = theArea
        index += 1
    while( index <= numOfYWaves )
