Display
need some help on generating multiple plots and export.
tried to use
function plot() string wavenames = wavelist("*",";","") string waveno1 , waveno2, waveno3 wave wave1, wave2, wave3 variable i for (i=0;i<itemsinlist(wavenames,";"); i=i+1) waveno1 = stringfromlist(i,wavenames,";") waveno2= waveno1 +"#1" waveno3 = waveno1+ "#2" wave wave1 = $waveno1 wave wave2 = $waveno2 wave wave3= $waveno3 display wave1 vs timeline endfor end
but cannot get to work.
Can Display not accept a 'reference name' but only the exact real wave name?
When I compile your function I get an error because Timeline is not defined.
To test I cobbled this test and it compiles and executes ok. So I am guessing the error is in the definition or lack thereof of timeline.
April 1, 2018 at 06:05 pm - Permalink
I changed
display wave1 vs Timeline
into
and it worked. Seems here that only $waveno1 can be accepted but not wave1 and I don't know why (confused)
Timeline is a wave that is already existent in my data folder, and I thought I can use without referencing. Can I?
April 1, 2018 at 06:14 pm - Permalink
Timeline is a wave that is already existent in my data folder, and I thought I can use without referencing. Can I?[/quote]
Remove the first declaration of
. I believe it may "confuse" the issue to declare the waves twice.--
April 1, 2018 at 07:06 pm - Permalink
Maybe have a look at
displayhelptopic "User-defined Trace Names"
If you want do achieve something different, let us know.
HJ
April 2, 2018 at 02:12 am - Permalink
