A long stringList
Hello
I have a question on the length of a string list that is valid and how can this one list be written in a multiple lines in procedure window.
I am getting the expected terminating quote error and I am guessing I exceed the maximum length allow for a string list.
How do I solve this problem? besides constructing multiple lists and splitting the original list?
Presuming that you are generating code, I (and others) would likely recommend a different approach than writing to a string list.
Write the code lines to a notebook.
If you are asking about writing code with long lines, Igor 7 has a line continuation feature:
For example:
Function foo()
    String longList="abc;def;ghi;jkl;" + \
    "mno;pqr;stu;xyz;"
    print longList
Note that each line must have an opening and closing ", so the string + operator is needed.
For more details:
DisplayHelpTopic "Line Continuation"
May I ask how to execute the codes in a notebook? If I understand it correctly?
For example:
Function foo()
    "mno;pqr;stu;xyz;"
    print longList
For more details:
Thanks! Does Igor 6 have similar features?
Details are in the help topic Notebooks -> Notebooks as Worksheets
mwpro wrote:
Thanks! Does Igor 6 have similar [line continuation] features?
It does not, sorry.
How about the good old ...
Function foo()
    longList+="mno;pqr;stu;xyz;"
    print longList
... although I agree, that the problem should be approached differently.
