Axis title emerges when making a map
peterming
I find that axis titles emerge automatically when I try to make a map. These titles could be "Degree", "Longitude", or "Latitude", which can not be deleted from modifying axis. I asked my colleagues for this issue, not solving but hinting that this could be because of some templetes linked but not sure of.
Best regards,
Jing
HJ
November 10, 2017 at 05:15 am - Permalink
SetScale
November 10, 2017 at 05:56 am - Permalink
Instead of deleting the dimension label, I believe that you can override it using the Modify Axis dialog, Axis label tab, Units drop down (left side of dialog window), Manual Override item.
Also, I wonder if there could be multiple axes in use. So check the Axis drop down at the top left of the Modify Axis dialog for axes that may not be obvious from a simple inspection of the graph.
Otherwise, the minimum working example is needed.
November 10, 2017 at 06:14 am - Permalink
Sorry for late response. Yes, this helped.
Thanks.
Cheers,
Peter
November 24, 2017 at 03:31 am - Permalink
setscale
I would rather prevent the automatic labeling usingLabel bottom "\u#2"
HJ
November 24, 2017 at 07:16 am - Permalink
This issue was solved by switching off the preference in the Misc popup or directly deleting the "Igor Pro 7" folder (/Users/XXX/Library/Preferences/WaveMetrics/Igor\ Pro\ 7) and the "Igor Pro 7.ini" file (/Users/mingjing/Library/Preferences/WaveMetrics/Igor\ Pro\ 7.ini)
Cheers,
Peter
November 30, 2017 at 01:48 am - Permalink
