Dynamic PopupMenu
I would like to modify the list contents of a PopupMenu (SelectSection), based on the selections made by another PopupMenu (SelectData). The code below, using
ControlUpdate is not working for me. Tried ModifyControl which was also not appropriate. The example below, when case D is chosen the list in the "SelectSection" popupMenu should now include the updated contents of "SectionList".Anyone with suggestions?
R.
Function Proc_SelectData(PU_Struct) : PopupMenuControl STRUCT WMPopupAction &PU_Struct String sWin = PU_Struct.win SetActiveSubwindow $sWin //This activates the subpanel where controls were selected if(PU_Struct.eventCode == 2) // mouse up Strswitch (PU_Struct.popStr) Case "A": break Case "B": break Case "C": Case "D": string quote = "\"" String/G SectionList = quote + "Second;Third;Fourth;" + quote ControlUpdate /W=$sWin SelectSection break Case "Frequency (Hz)": break Case "Frequency (bpm)": break Case "Gap Time": break EndSwitch SetActiveSubwindow ## //Go back to parent window Else Return 0 EndIF End
DisplayHelpTopic "PopupMenu"and there "Setting The Popup Menu Items/function call".October 30, 2017 at 01:44 pm - Permalink
I can see how plugging in a function as a value sort of makes sense, but something like
ModifyControlseemed to make more sense. I am sure there is a good reason for this.Unfortunately I'm getting a compiling error when trying to use the exact code given as example from the help files.
I do not have any other "List" strings in my code that could originate any sort of conflict (even if this is a local string variable) - nonetheless I get a "Unknown/Inappropriate name or symbol" error (??!!).
Check screen-shot attached.
Any idea why this behavior?
Best,
R.
October 30, 2017 at 03:22 pm - Permalink
October 30, 2017 at 03:52 pm - Permalink
Cheers,
R.
October 30, 2017 at 11:34 pm - Permalink
October 31, 2017 at 09:30 am - Permalink
