time format
mwpro
String columnInfoStr = "" columnInfoStr += "C=1,F=6,T=4,N=DateLC;" columnInfoStr += "C=1,F=7,T=4,N=TimeLC;" columnInfoStr += "C=1,F=0,T=4,N=CO2;" LoadWave/Q/A/D/J/O/W/L={1,2,0,0,0}/B= columninfostr
but the DateLiCor only shows 2017 for the entire wave. I had the same issue with or without specifying B. I also wonder what should be used for numeric values, help file says 0-5, what does each mean?
May I also ask how do I introduce a path for loadwave function? Right now I wait for the window asking for the file location after executing the command.
Many thanks!!
September 6, 2017 at 01:11 pm - Permalink
September 6, 2017 at 02:34 pm - Permalink
September 6, 2017 at 04:39 pm - Permalink
Any of those values produces the same result. Those are just the numbers between -2 and 10 that aren't used for other purposes. Use F=0.
Use /P=path
And also specify the name of the file as the last (string) parameter. Obviously you must supply/know this name to do this.
September 6, 2017 at 04:50 pm - Permalink
September 7, 2017 at 03:30 pm - Permalink
It does, and you're welcome!
September 7, 2017 at 04:08 pm - Permalink
