HJDrescher I think matrix-=samewave[p] should do the job. HJ Log in or register to post comments August 1, 2017 at 08:39 am - Permalink
Natmih Thank's! work's great! Log in or register to post comments August 4, 2017 at 12:12 am - Permalink
Igor The solution suggested above is perfectly valid. However, if you are working with matrices you may want to get acquainted with MatrixOP where you would use:MatrixOP/O resultW=matrixWave-colRepeat(vectorWave,numCols(matrixWave)) A.G. WaveMetrics, Inc. Log in or register to post comments August 4, 2017 at 10:09 am - Permalink
matrix-=samewave[p]
should do the job.
HJ
