Wave dependency in user-defined functions
Function Dependency_test1() make /O/N=5 wave1 wave1={1,2,3,4,5} make /O /N=5 wave2 wave2:=wave1 End
but always get an error "Can't use local variables in dependency formula" during compile.
This seems to work in the command line. I am not sure what I am doing wrong?
Thank you!
When I use
Edit root:wave1,root:wave2I can change values in wave1 and those in wave2 change automagically.Hope this helps,
Kurt
July 7, 2017 at 02:41 am - Permalink
July 7, 2017 at 03:11 am - Permalink
If you now run this function, then go to Misc->Object Status you will see that wave2 depends on wave1 via this formula: "root:'liberal name for my wave'". Note the data folder path, and special quoting for the liberal name.
July 7, 2017 at 09:56 am - Permalink
