Create masks that partition an image from a voronoi tesselation
kpantzas
I am using Igor to process images of crystal lattices. The image contain projections of atomic columns of a given lattice. I identify the atomic columns using
ImageAnalyzeParticles
. Then, I pass the XY positions of the centers of the identified particles to ImageTransform voronoi
to compute a voronoi tesselation of the image. I would like to use this tesselation to compute statistics for a region around each atomic column.How can I link each polygon from the tesselation to the atomic columns it encompasses? I have not found anything in the documentation on this.
I've attached an example where I've overlaid the centers of the atomic columns (blue dots) and the voronoi tesselation (red vertices) on the original image.
Thank you for your help.
I hope this helps,
July 5, 2017 at 12:04 pm - Permalink
ImageBoundaryToMask was indeed the only missing ingredient.
July 13, 2017 at 07:51 am - Permalink
