Giving desired name to Wave Average wave output - can I modify a read only procedure?
YonatanHo
(I've accidentally posted this in the IgorExchange forum)
In short, I’ve noticed that in the Average Waves package I cannot use a decimal point for the output average wave name, for example: charge0.4_avg (bad).
My question was answered by HJ Drescher and Jim Prouty.
They suggested changing line 833, in the Average waves package to:
String AppCom = "AppendToGraph"+AFlags+" "+PossiblyQuoteName(AveWaveName)+XWaveInfo
However, the package procedure is a read only one.
Can I unlock it somehow to specifically change this line?
Cheers,
Yonatan
Open it in your favorite text editor and do the changes.
If you want to do the changes in Igor 6 you will have to start a new experiment, drag the file on the grey background area. In case the pen symbol is ruled out (where the lock symbol has been before) click on it to enable editing.
Igor 7 complains that the file is in use. I'd go for a third party editor in this case.
HJ
June 26, 2017 at 03:53 am - Permalink
Right-click the file first to make sure it is not marked read-only.
Then copy it back.
Use an Admin account.
June 26, 2017 at 11:19 am - Permalink
Thank you guys for your time and effort!
Cheers,
Y.H
June 28, 2017 at 02:38 pm - Permalink
override
like so:String ctrlName
SVAR/Z ListExpression=root:Packages:WM_WavesAverage:ListExpression
if (!SVAR_Exists(ListExpression))
DoAlert 0, "Some data required for the operation cannot be found. Try closing the panel and re-opening it."
return -1
SVAR/Z ErrorWaveName=root:Packages:WM_WavesAverage:ErrorWaveName
if (!SVAR_Exists(ErrorWaveName))
return -1
SVAR/Z AveWaveName=root:Packages:WM_WavesAverage:AveWaveName
if (!SVAR_Exists(AveWaveName))
return -1
SVAR/Z WA_ListOfWaves=root:Packages:WM_WavesAverage:WA_ListOfWaves
if (!SVAR_Exists(WA_ListOfWaves))
return -1
NVAR/Z nSD=root:Packages:WM_WavesAverage:nSD
if (!NVAR_Exists(nSD))
return -1
NVAR/Z ConfInterval=root:Packages:WM_WavesAverage:ConfInterval
if (!NVAR_Exists(ConfInterval))
return -1
NVAR/Z ErrorMenuSelection=root:Packages:WM_WavesAverage:ErrorMenuSelection
if (!NVAR_Exists(ErrorMenuSelection))
return -1
String theList="", theXList=""
String aWave
String TopGraph=WinName(0,1)
String TopTable=WinName(0,2)
Variable DoConf
Variable Interval
Variable AppndGrph=0, numXWaves=0
ControlInfo WaveSourceMenu
Variable ListSource=V_value
if (ListSource == 1) // by Name
theList = WaveList(ListExpression, ";", "")
if (ListSource == 2) // from Top Graph
if (strlen(TopGraph) == 0)
DoAlert 0, "There are no graphs"
return -1
// theList = WaveListfromGraph(ListExpression, ";", TopGraph)
numXWaves= XYWaveListfromGraph(ListExpression, TopGraph,theList,theXList)
// if( numXWaves == 0 )
// theXList=""
// endif
ControlInfo AverageAppendToGraphCheck
AppndGrph = V_value
if (ListSource == 3) // from Top Table
if (strlen(TopTable) == 0)
DoAlert 0, "There are no tables"
return -1
theList = WA_TableWaveList("*", ";", TopTable)
Variable ErrorType = 0
ControlInfo GenErrorCheck
if (V_value)
ErrorType = ErrorMenuSelection
if (ErrorType == 1)
Interval = nSD
if (ErrorType == 2)
Interval = ConfInterval
Variable numWaves= ItemsInList(theList)
if (numWaves == 0)
DoAlert 0, "You have no waves selected. If you have selected From Top Graph, make sure the Wave Name Template is correct."
return -1
// Version 6.23: changed to Yes, No DoAlert
if (numWaves == 1)
// DoAlert 0, "You have only one wave selected ("+theList+" if you have selected From Top Graph, make sure the Wave Name Template is correct."
//return -2
String warning= "Only one wave selected ("+StringFromList(0,theList)+")."
warning += " Make sure the Wave Name Template ( \""+ListExpression+"\" ) is correct."
warning += "\r\rContinue anyway?"
DoAlert 1, warning
if( V_flag != 1 ) // 1 == yes
return -2
ErrorType=0
Variable/G root:Packages:WM_WavesAverage:numWaves = numWaves // for the New Graph button proc
ControlInfo print
if (V_value)
Print "Averaging "+num2istr(numWaves)+" waves: "+ReplaceString(";",RemoveEnding(theList,";"),", ")
Variable wasPointByPoint= fWaveAverage(theList, theXList, ErrorType, Interval, AveWaveName, ErrorWaveName)
Variable disableXWave= 1 // hide
if( wasPointByPoint >= 0 ) // < 0 means fWaveAverage reported an error
if (AppndGrph)
DoWindow/F $(WinName(0,1))
aWave = StringFromList(0, theList, ";")
CheckDisplayed $AveWaveName
if (V_flag == 0)
String TInfo = traceinfo("", NameOfWave($(aWave)),0)
String AFlags=StringByKey("AXISFLAGS",TInfo)
String XWaveInfo = PossiblyQuoteName(StringByKey("XWAVE", TInfo))
if (wasPointByPoint && strlen(XWAveInfo) > 0)
XWaveInfo = " vs "+StringByKey("XWAVEDF", TInfo)+XWaveInfo
XWaveInfo= ""
String AppCom = "AppendToGraph "+AFlags+" "+PossiblyQuoteName(AveWaveName)+XWaveInfo
Execute AppCom
if (ErrorType == 0)
ErrorBars $AveWaveName, OFF
ErrorBars $AveWaveName, Y wave=($ErrorWaveName, $ErrorWaveName)
if( wasPointByPoint )
disableXWave= 0 // enabled and showing
disableXWave= 2 // disabled but showing
// force calculated
PopupMenu WavesAverageGraphXWave, win=WaveAveragePanel, mode=1
ModifyControl WavesAverageGraphXWave, win=WaveAveragePanel, disable= disableXWave
WA_ListOfWaves = theList
best,
_sk
June 29, 2017 at 12:37 am - Permalink
