Differential-Algebraic equation help
integratemate
I am brand new to using Igor Pro, so I know almost nothing about its interface and language. A paper that I read through disclosed a method for determining a particular parameter by running a simulation of a polymerization and fitting the simulated data to the experimental data by adjusting that parameter. The simulation involves solving a system of 6 ODEs with the Backwards Differentiation method, in addition to updating a number of algebraic equations at each time step during numerical integration. Could someone give me a brief tutorial on how I might go about solving the ODEs and algebraic equations simultaneously in Igor?
Start by reading the description of how to use IntegrateODE. Copy this command, paste it into Igor's command line and hit Enter:
DisplayHelpTopic "Solving Differential Equations"
If you haven't done it already, I strongly recommend selecting Help->Getting Started and doing at least the first half of the Guided Tour.
June 23, 2017 at 09:07 am - Permalink
I already had read through the "Solving Differential Equations" tutorial and help section, but it never mentioned how to incorporate algebraic equations at each time step as well. Any quick tips?
June 23, 2017 at 09:36 am - Permalink
If you really have a system with derivatives that depend on the time of a given step, it is passed into your function via the second input parameter of the derivative function. In the examples, that is generally called either "xx" or "tt".
June 23, 2017 at 09:58 am - Permalink
I think I now know how to use the Derivative function to input my differential equations, but what I still am unsure of is how to incorporate non-differential equations into the same system and have those solved with the differential equations (the algebraic equations). Basically, some of the differential equations have terms in them that are dependent on other non-differential equations, so both the differential and algebraic equations needs to be solved simultaneously. For a short example, I might have:
dx/dt = Ax + y
dy/dt = By - z
z = C*x
So the first two are differentials, but the third is algebraic. I know in this example I could just substitute in the expression for z, but in my actual application the algebraic expressions are much more complex, so simplification is difficult. Therefore, I was wondering if Igor takes non=differential equations with the differentials, (i.e. could I list all three of those relationships in the Derivative function?)
June 23, 2017 at 10:38 am - Permalink
June 23, 2017 at 10:45 am - Permalink
I have attached here the equations in case that would help. I appreciate your time by the way; it would be so helpful if I could figure this thing out. Equations 9-14 are the differential equations, with the one non-integrable parameter being Tx and Ty. Tx and Ty can be computed from a series of algebraic relationships that could be simplified, which are equations 16, 18-19, 21-24. One more thing: although the differential equations need to be solved, it is actually the algebraic expression given in equation 24 that will yield the points I need for the plot I want to generate (the Disp variable vs. time). This equation is dependent on the differential equations, however, which is why I need to solve all of these in the first place.
June 23, 2017 at 10:58 am - Permalink
June 23, 2017 at 02:58 pm - Permalink
Thanks so much I'll give it a look.
June 23, 2017 at 04:26 pm - Permalink
Hello again,
So I read through the waveform arithmetic and assignment section and I still have a few questions. Firstly, yes, the ODE solutions are inputs to algebraic equations, but the outputs of some of the algebraic equations are also inputs in the ODEs. For example, Tx and Ty are variables that are both in the ODEs as well as dependent on the ODEs through algebraic relationships. So I can't just solve the ODEs first, then plug in the outputs as inputs to the algebraic equations, because in order to solve the ODEs, I need to update the algebraic values along the way. So where should I algebraically define the waves Tx and Ty: within the derivative function or outside of it, but before it? Also, how can I perform operations on waves, such as multiplying two waves together? I can't find the proper syntax for this type of operation.
June 26, 2017 at 08:24 am - Permalink
The highlighted "1" in the equation for dydt[2] is just a placeholder that is actually supposed to be a variable called Tx. This variable Tx is dependent on the differential state variables yw[1] and yw[2]. So the differential equation for dydt[2] requires the current value of Tx as an input, but Tx then requires the updated values of yw[1] and yw[2] as inputs for the next step. I am not sure how to incorporate this.
June 26, 2017 at 09:22 am - Permalink
If you have three waves, a, b, and c, you can fill c with the product of a and b with a simple assignment:
c = a*b
. That assumes that a, b, and c all have the same number of points. It also doesn't handle the case of multidimensional waves.John Weeks
June 26, 2017 at 09:31 am - Permalink
It may be that you need a different method than we offer.
June 26, 2017 at 09:36 am - Permalink
What i mean is this: the set of equations dydt[0-5] define the derivatives of the six inputs yw[0-5]. This is a system of ODEs with 6 ODEs. However, one of the terms in the derivative dydt[2] is not an input that has a differential equation like the other inputs yw[0-5], but rather an input that has an algebraic dependence on those other inputs. As a simplified version of the scenario:
dydt[0]=yw[0]*pw[0]
dydt[1]=yw[1]-yw[0]+Tx
Tx=yw[1]*yw[0]/pw[1]
So its a system of 2 ODEs, dydt[0] and dydt[1], but a third non-differential equation for Tx is necessary that has yw[0] and yw[1] as inputs.
June 26, 2017 at 09:44 am - Permalink
How about:
dydt[0]=yw[0]*pw[0]
June 26, 2017 at 11:05 am - Permalink
Perfect thanks. And I can define this variable within the derivative function? Lastly, will the changing values of Tx be stored in an array so that I can view the entire range of Tx values over time?
June 26, 2017 at 11:16 am - Permalink
Yes. Please read the Programming help file.
No. Only the solution values will be saved. But since you have an expression for generating Tx from the solution values, you can re-generate those values after IntegrateODE finishes.
June 26, 2017 at 11:45 am - Permalink
Alright the procedure with all of my new variables compiles fine, but now the IntegrateODE command results in an error saying the step size has become too small. I tried raising the error tolerance significantly with no success. Any final tips? I know this exact set of equations has been done in Igor before because it was in the experimental section of another paper, but the detail is very limited so I don't know how they did it. Here is what I have in the procedure that compiles fine. Is there any glaring error that you see that would make you think this can't be done (see attached)
June 26, 2017 at 01:42 pm - Permalink
