I get a function execution error for make. name already exists as a wave. I've run a search through all my procedure files, and confirmed that every single time I use 'make' I use make/o(with whatever other flags are relevant for that wave). Is there some implicit use of 'make' in native Igor functions that can throw this error?
I don't think Make/O will overwrite a wave of another type. Make/O MyWave will not overwrite MyWave if it already exist as a text wave, but the error message you get will usually tell you if that is the case.
@_sk: This provokes already a compilation error "name already exists as a function" in IP6 and IP7
Speaking of that, which IP version causes the anomalous error?
HJ
HJ
Yes, indeed the error is, as you suggested, name already exists as a function. Although it need not be triggered at compile time but on runtime if executed as a string, i.e.: execute/q"make/o x" (compiles fine, runtime error on some interpreter level compilation, I guess).
Thank you all very much. I'm using a 64 bit version of 6.37. I'd read about the debugger but I had no idea how to actually activate it. This is my new favorite thing. There was a make without an /o that I missed while skipping through the code.
Right click on the code check 'Enable Debugger' & 'Debug on Error'. It should stop after the line that causes the error.
HJ
June 22, 2017 at 09:12 am - Permalink
June 22, 2017 at 01:03 pm - Permalink
etc...
That's why I prefix wave names with
w_
.best,
_sk
June 23, 2017 at 12:50 am - Permalink
HJ
June 23, 2017 at 01:21 am - Permalink
execute/q "make/o x"
(compiles fine, runtime error on some interpreter level compilation, I guess).best,
_sk
June 23, 2017 at 02:06 am - Permalink
This info might help to trace the mistake.
HJ
June 23, 2017 at 04:59 am - Permalink
June 23, 2017 at 10:20 am - Permalink
