Implementing frame slider for image volume display in panel
euaruksakul
Thanks a lot!
Function SliderProc_ImgFrame(sa) : SliderControl STRUCT WMSliderAction &sa switch( sa.eventCode ) case -1: // control being killed break default: if( sa.eventCode & 1 ) // value set Variable curval = sa.curval modifyimage /W=SLP_ImgXPS_Panel_01#IX_ImgW WF01 plane=(curval) endif break endswitch return 0 End
For the slider's limit, I use "
Slider Slider_Img limits={0,dimsize(ImgVolW,2),1}
I think, the dimension slide has to go correctly from 0 but to:
dimsize(ImgVolW,2)-1
Secondly, you can write the switch and actually use the cases, something like:
As to slow, what is the dimension of the images?
best,
_sk
March 6, 2017 at 01:16 am - Permalink
Now Igor would use the global min and max values to compute the same scaling for all frames.
I hope this helps,
March 7, 2017 at 07:49 am - Permalink
March 7, 2017 at 08:19 am - Permalink
_SK - Thanks a lot for pointing out the mistake.
March 9, 2017 at 01:05 am - Permalink
