SetAxis operates at the end of procedure?
I am writing a procedure for which I plot some data.
it goes something like:
// THERE IS SOME CODE ABOVE //Plot Original Dataset Display /K=1 /W=(0, 180, 320, 450) /N=OriginalPlot Original_Y vs Original_T SetAxis /W=OriginalPlot /a=2 bottom 700, 1200 //Convert frame number to timepoints Prompt FPS, "Frames per second: " DoPrompt "Please indicate the frame rate at which the data was collected", FPS; if (V_flag) return -1 endif Duplicate /O Original_T, Original_Time Original_Time /= FPS AppendToTable /W=Data Original_Time // THERE IS SOME CODE BELOW
So, there is a
DoPrompt
after the display
and SetAxis
operations.My problem is that
SetAxis
only kicks in at the end of the procedure. Why does it not updates the graph before the DoPrompt
? Not sure why this happens.I have no
DelayUpdate
operations written anywhere and still this happens.No flags in
SetAxis
that could induce this.Any ideas on how to update the graph before
DoPrompt
?Many thnaks!!
R.
DoUpdate
immediately after the line withSetAxis
.March 3, 2017 at 08:42 am - Permalink
March 3, 2017 at 08:52 am - Permalink
March 7, 2017 at 09:49 am - Permalink
