I want to upload a .txt file as a 1 column wave, this is what I have so far, I am not sure what the next steps would be. I have attached the .txt file that I am trying to upload.
From "I want to upload a .txt file as a 1 column wave", I am guessing that you want to concatenate all of the columns in the matrix wave created by LoadWave/G/M into a single 1D wave. After LoadWave/G/M, you can use Redimension to convert the wave to 1D. Something like:
String name = StringFromList(0, S_waveNames)// Get name of the wave created by LoadWave Wave w = $name// Create a wave reference Variable numRows = DimSize(w, 0) Variable numColumns = DimSize(w, 1) Variable numPoints = numRows * numColumns Redimension/N=(numPoints) w
It still is not working, I keep getting an error message that states: while executing LoadWave: no data was found in file.
Function Loadtimeaxis (cwl) Variable cwl NewPath/O dataFolder //dialog box to get the data folder path String callist=ListFilesofType("dataFolder",1,".txt") String timefile=StringFromList(0,callist) LoadWave/G/M/P=datafolder timefile String name = StringFromList(0,timefile)// Get name of the wave created by LoadWave Wave w = $name// Create a wave reference Variable numRows = DimSize(w, 0) Variable numColumns = DimSize(w, 1) Variable numPoints = numRows * numColumns Redimension/N=(numPoints) w End
Although my web browser makes it look like your file contains numbers in columns, in fact, it contains one long row of number separated by tabs.
You can't use LoadWave/G for this data. To understand why, execute this:
DisplayHelpTopic"Loading General Text Files"
You can use LoadWave/J (Load Delimited Text). Here is a function that may get you started in the right direction:
Menu"Load Waves"// Add to Load Waves submenu "Load Time File...", LoadTimeFile("", "") End
Function LoadTimeFile(pathName, fileName) String pathName // Name of an Igor symbolic path or "" String fileName // Name of file or full path to file
// First get a valid reference to a file. if((strlen(pathName)==0)||(strlen(fileName)==0)) // Display dialog looking for file. Variable refNum String filters = "Text Files (*.txt):.txt;"
filters += "All Files:.*;" Open/D/R/P=$pathName/F=filters refNum as fileName
fileName = S_fileName // S_fileName is set by Open/D if(strlen(fileName) == 0)// User cancelled? return -1 endif endif
LoadWave/J/M/P=$pathName/Q fileName String listOfWaves = S_waveNames // S_waveNames is set by LoadWave String filePath = S_path + S_fileName // S_path and S_fileName are set by LoadWave
String name = StringFromList(0, listOfWaves) Wave w = $name// Create a wave reference
Wave w = $name // Create a wave reference
BTW, when you post Igor code, use <igor> and </igor> tags as explained at http://www.igorexchange.com/node/3221
November 18, 2016 at 03:16 pm - Permalink
Variable cwl
String name = StringFromList(0,timefile) // Get name of the wave created by LoadWave
November 21, 2016 at 12:50 pm - Permalink
if ((strlen(pathName)==0) || (strlen(fileName)==0))
Variable refNum
Open/D/R/P=$pathName /F=filters refNum as fileName
if (strlen(fileName) == 0) // User cancelled?
return -1
// Redimension as 1D wave
Printf "Loaded wave %s from \"%s\"\r", name, filePath
return 0 // Success
To clarify what a symbolic path is versus a data folder, execute these commands:
DisplayHelpTopic "Data Folders"
November 21, 2016 at 01:41 pm - Permalink
