Turning a .txt file into a wave
I want to upload a .txt file as a 1 column wave, this is what I have so far, I am not sure what the next steps would be. I have attached the .txt file that I am trying to upload.
NewPath/O dataFolder
String callist=ListFilesofType("dataFolder",1,".txt")
String timefile=StringFromList(0,callist)
LoadWave/G/M/D/A=wave/P=datafolder timefile
Thanks
spot2.txt (5.72 KB)
From "I want to upload a .txt file as a 1 column wave", I am guessing that you want to concatenate all of the columns in the matrix wave created by LoadWave/G/M into a single 1D wave. After LoadWave/G/M, you can use Redimension to convert the wave to 1D. Something like:
    String name = StringFromList(0, S_waveNames)    // Get name of the wave created by LoadWave
    Wave w = $name  // Create a wave reference
    Variable numRows = DimSize(w, 0)
    Variable numColumns = DimSize(w, 1)
    Variable numPoints = numRows * numColumns
    Redimension/N=(numPoints) w
BTW, when you post Igor code, use <igor> and </igor> tags as explained at http://www.igorexchange.com/node/3221
It still is not working, I keep getting an error message that states: while executing LoadWave: no data was found in file.
 Function Loadtimeaxis (cwl)
    Variable cwl
    NewPath/O dataFolder //dialog box to get the data folder path
    LoadWave/G/M/P=datafolder timefile
    String name = StringFromList(0,timefile)    // Get name of the wave created by LoadWave
Although my web browser makes it look like your file contains numbers in columns, in fact, it contains one long row of number separated by tabs.
You can't use LoadWave/G for this data. To understand why, execute this:
DisplayHelpTopic "Loading General Text Files"
You can use LoadWave/J (Load Delimited Text). Here is a function that may get you started in the right direction:
Menu "Load Waves"           // Add to Load Waves submenu
    "Load Time File...", LoadTimeFile("", "")
Function LoadTimeFile(pathName, fileName)
    String pathName     // Name of an Igor symbolic path or ""
    String fileName         // Name of file or full path to file
    // First get a valid reference to a file.
    if ((strlen(pathName)==0) || (strlen(fileName)==0))
        // Display dialog looking for file.
        Variable refNum
        String filters = "Text Files (*.txt):.txt;"
        filters += "All Files:.*;"
        Open/D/R/P=$pathName /F=filters refNum as fileName
        fileName = S_fileName           // S_fileName is set by Open/D
        if (strlen(fileName) == 0)      // User cancelled?
            return -1
    LoadWave/J/M/P=$pathName/Q fileName
    String listOfWaves = S_waveNames        // S_waveNames is set by LoadWave
    String filePath = S_path + S_fileName   // S_path and S_fileName are set by LoadWave
    String name = StringFromList(0, listOfWaves)
    // Redimension as 1D wave
    Printf "Loaded wave %s from \"%s\"\r", name, filePath
    return 0    // Success
To clarify what a symbolic path is versus a data folder, execute these commands:
DisplayHelpTopic "Symbolic Paths"
DisplayHelpTopic "Data Folders"
