Ensuring unique trace names
string yN=ywaven+foldername+subfoldername appendtograph /W=$chartname /L=$ywaven ywave /TN=$yN vs xwave modifygraph /W=$chartname rgb($yN) = (red,green,blue)
If yN happens to exist already due to plotting vs a different x-wave in a previous call, or because yN exceeds string limits, I understand that Igor will use instance notation to change the trace name from whatever yN is to "yN"#1.
Is there a way for me to know that the trace name has been modified with instance notification so that the last line modifies the trace I just appended instead of the first instance named yN?
I experimented with using the uniquename function, but I don't think there is an object type that works for traces.
I used checkname(tracename,15) for both an existing and non-existent trace name on the graph in question, and both returned -1.
displayhelptopic "TraceNameList"
HJ
May 29, 2016 at 06:51 am - Permalink
I had started to write a function to run a for-endfor loop to check (and modify) the proposed trace name vs all the elements in TraceNameList, but thought that there might be a more elegant way to do so via a built-in function.
It's also worth noting that if you're using a procedure to create trace names, you need to be aware of the maximum allowable length for a trace name. When I execute this code:
the output from the
print tracenamelist
command is the following:a000000000000000000000000000001;a000000000000000000000000000000;a000000000000000000000000000000#1;
Applying
strlen()
to each of the entries in thetracenamelist
output shows an output of 31, 31, and 33: this suggests that the maximum length that you can use for a trace name request is 31 bytes, but Igor can add the "#1", "#2", etc. to the end of an identical trace name to differentiate between them and will store that difference.Understanding that difference is important to proper handling of automatically generated trace names.
May 29, 2016 at 01:04 pm - Permalink
If (StringMatch(TraceNameList(graphNameStr, separatorStr, optionsFlag ), "*"+matchStr+"*" ))
is rather elegant if it's not invoked too often.In your example, even quotes for liberal names, e.g. '1st trace', do not work. That's an interesting point. I assumed that the #n versions just use liberal names. But obviously it works in a different way.
HJ
May 29, 2016 at 03:25 pm - Permalink
displayhelptopic "hash"
).So you would be generating the name strings:
string trace_name = name_prefix + num2str(number)
then hashing this string:
string trace_name_hash = hash(trace_name , 1)
and hoping for no collisions (your uniqueness requirement) on the hash function. The last statement can be pretty reasonable for any meaningful set of objects to be hashed.
Good luck.
[edit] of course, you would have to keep track of which trace_name corresponds to which trace_name_hash in a separate text wave.
May 29, 2016 at 11:53 pm - Permalink
Set every trace to something unique via "T1, T2, ..." and then add some metadata using the userData keyword of
ModifyGraph
. Using the userData you can then access any trace you want without having to know about its name.May 30, 2016 at 04:30 am - Permalink
May 31, 2016 at 10:14 am - Permalink
