Error while opening .uxp file
Dear All,
I am facing following error when I reopened a saved .uxp experiment.
Error loading wave file: “TTtoPS.ibw”
the file or folder could not be found.
The wave may be needed to recreate a graph, table or other object in the experiment.
Do you want to look for the wave file?
Also for “TTPSFNames.ibw”,PSSymbolNames.ibw".
Any idea what went wrong between different day. I am not sharing any waves with any other experiment.
Thanks in advance for your help.
Best,
Maniraj
Not sure what went wrong but those are Igor generated waves created when an EPS export is done.
You probably don't need them and will likely be regenerated if you export again.
I tried creating a .uxp after an EPS export and it loaded fine. The files are created in root:Packages:PSFontInfo.
Larry Hutchinson
WaveMetrics
support@WaveMetrics.com
Okey, I was trying to export an eps file. It took quite a lot of time because file size was nearly 350 MB. Possibly something went wrong. I will try as you suggested. Thanks for your post.
