Error while opening .uxp file
maniraj
I am facing following error when I reopened a saved .uxp experiment.
Error loading wave file: “TTtoPS.ibw”
the file or folder could not be found.
The wave may be needed to recreate a graph, table or other object in the experiment.
Do you want to look for the wave file?
Also for “TTPSFNames.ibw”,PSSymbolNames.ibw".
Any idea what went wrong between different day. I am not sharing any waves with any other experiment.
Thanks in advance for your help.
Best,
Maniraj
You probably don't need them and will likely be regenerated if you export again.
I tried creating a .uxp after an EPS export and it loaded fine. The files are created in root:Packages:PSFontInfo.
Larry Hutchinson
WaveMetrics
support@WaveMetrics.com
April 5, 2016 at 01:46 pm - Permalink
April 6, 2016 at 05:05 am - Permalink
