Automating Multipeak Fitting
If I run the fit manually and relocate the output folder to root as well as rename as "peaksframe_0" for resultDFBase equal to "peaksframe"; as well as rename (currently manually) the files that should be named "PeakCoefs0" and "PeakCoefs0esp" for the PeakCoefWaveFormat equal to "PeakCoefs%d", ans subsequently run MPF2_AutoMPFit with option "0" (uses initial guesses for each spectrum) it does nothing, doesn't even try. I check and the ywaveslist and xwaveslist are populated properly (generate in the GetFromLabview() macro).
If I run MPF2_AutoMPFit with option "5" instead of "0" (no initial guesses) and then delete all peaksframe_i output files except for "peaksframe_0" and rerun MPF2_AutoMPFit with option "0" it works fine. Am I crazy? What am I missing? Thank you for any help.
I will attach the routine that I am using, if sample data helps just let me know and I can supply that as well.
B
PS: if you still have energy help me with this other issue: I used the function KillDataFolder to kill "peaksframe_0" in one of my many failed attempts, and since then "DuplicateDataFolder/O" is not getting compiled any longer, only if I remove the "/O" flag. Is this normal? How can I get that functionality back? Should I reinstall Igorpro? This basically made me change my "storethefit()" function.
the function
MPF2_AutoFitreturns a numeric return value. Can you post that for the case where it does not work? Have you looked at the documentation viaDisplayHelpTopic "MPF2_AutoMPFit()"?With
initialguessOptions=0it expects coefficient waves in resultDFBase where the names of the waves must match peakCoefWaveFormat.March 14, 2016 at 04:29 pm - Permalink
March 14, 2016 at 09:08 pm - Permalink
March 15, 2016 at 09:02 am - Permalink
variable ret = MPF2_AutoMPFIT(...)and then compare the value with the documentation.March 15, 2016 at 04:37 am - Permalink
March 15, 2016 at 09:04 am - Permalink
