graph visibility
Aardvark
One way I found myself going lately is to create very small graphs, so that many can fit my screen. But then sometimes they are too small to just export them and one has to resize... that is tedious work :-(.
It would be great if the minimization/maximization of graphs could be done in an additional way: By simply leftclicking e.g. a small symbol (e.g. a magnification glass) that gets implemented by default in every upper left corner inside the graph or in the graph menu. Then the graph gets shrunk or enlarged, whatever the setting is, another click reverses it. Some keyboard shortcut for this would be sweet. The setting can be changed by rightclicking on that symbol, that then gives different options, such as range -200 to 200% or so.
What do you think?
You might want to check out http://www.igorexchange.com/project/ACL_WindowDesktops
February 7, 2016 at 12:42 pm - Permalink
February 7, 2016 at 05:31 pm - Permalink
