Help with ImageInterpolate
I have 1024 by 1024 grayscale image, represented in IGOR in the form of a 2D wave of I8 Interger data type. I would like to resample the image to a higher resolution to determine the location of certain features with sub-pixel resolution.
When I perform
 ImageInterpolate/FUNC=bilinear/RESL={2048,2048} Resample image
Igor return that there is a syntax error and highlights the name of the wave. Any clues on as to why I get this error?
I also tried
ImageInterpolate/D=2 Spline image
in a first attempt and I got a different error (insufficient input).
Any help would be much appreciated, as there is little in the documentation in the ways of examples on the ImageInterpolate function.
I am not the real expert, but the author of the operation is on vacation.
It looks to me like you don't want Resample- the documentation (which is sort of terse :) seems to imply that Resample does some sort of transformation of the image. I think you want the Bilinear method. More like this:
ImageInterpolate/RESL={2048,2048} Bilinear image
The "syntax error" generated by Resample is not very helpful. I suspect the operation is expecting /TRNS flag. It appears that the Resample keyword requests a specialized operation meant for correcting certain kinds of camera distortion.
Thanks for the reply! Indeed your syntax works. I'll keep playing around with ImageInterpolate it actually comes in handy for a variety of operations in my current experiment.
kpantzas wrote:
When I perform
You are mixing the syntax of various mutually exclusive features. There is no need to use /FUNC here nor should you use Resample for this application. It seems from your description that all you need is:
ImageInterpolate/U=2 bilinear image
You can use the explicit resolution with /RESL or /F={fx,fy} but the /U is the simplest.
