Unintended Change of Data Folder
Root
Root:Elm -->Contains global variables for panel
Root:Elm:'10000': -->Contains data for dataset ID 10000
Root:Elm:'10000':PM -->contains subset data
When I enter this function I am in the data folder PM
Function maskcalc(refPM, elmpm) wave refpm, elmpm string elmpmname = nameofwave(elmpm) NVAR maxPM = root:elm:g_maxPM NVAR maxelm = root:elm:g_maxElm if(stringmatch(elmpmname, "*temp*")) //if doing a temperature calibration duplicate/O refpm, mask_temp mask_temp = (refpm[p] > maxelm ) ? 0 :1 else duplicate/O refpm, maskwave maskwave = (refpm[p] > maxPM || elmpm[p] > maxelm ) ? 0 :1 //Current data folder gets moved to Root:Elm endif end
Why does the current data folder get moved to Root:Elm. I didn't set a new data folder?
Thanks
When I set a breakpoint to catch the debugger, an error gets printed to the command window:
** CurveFit gave error: Mask wave was null or missing
However when i undo the breakpoint and don't catch the debugger, the CurveFit Function works just fine
fit_ref_dusttrak_dustPM2_5= poly(W_coef,x)
W_coef={-0.02849,2.6754e-005,1.5411e-008}
V_chisq= 23870.2;V_npnts= 45684;V_numNaNs= 26624;V_numINFs= 0;
V_startRow= 0;V_endRow= 72322;
W_sigma={0.0161,1.02e-05,6.58e-09}
I've attached some images
January 19, 2016 at 02:57 pm - Permalink
January 19, 2016 at 04:03 pm - Permalink
I sent an igor experiment with adopted ipfs and data already loaded to support@wavemetrics.com.
Puneet
January 20, 2016 at 08:37 am - Permalink
