Igor print function working strangely
Here is my question: is there some hidden functionality of the print function in Igor which makes it print repeatedly in some circumstances? Below is the code for reference, I've annotated in all caps relevant portions.
Function Curves(sublist, wName)//doesnt return anything, just adds values. String sublist wave wName variable i, numNeg = 5 String label //THIS IS THE FOR LOOP WHERE, FOR EACH VALUE i, THERE SHOULD BE ONE THING PRINTED, BUT PRINTS i * some constant TIMES INSTEAD for(i = 0; i < numNeg; i+=1) wave current = $stringfromlist(i, sublist, "\r") label = num2str((i - 5) * 10) InsertPoints/M=1 DimSize(wName, 1), 1, wName InsertPoints/M=2 DimSize(wName, 2), 1, wName print "%%%%\r" + num2str(DimSize(wName, 0)) + "%%%%\r" //FUNCTION CALLED HERE wName[DimSize(wName, 0) - 1][i][]= FI(label, current) endfor end Function FI(label, current) String label wave current variable spikes, currentInjected, FI variable level = 0 findLevels/DEST=levels/Q current, level spikes = numpnts(levels) / 2 currentInjected = str2num(label) FI = spikes / currentInjected //CALLS PRINT HERE, BUT IT PRINTS REPEATEDLY, UP TO ~17 TIMES. print ("*********************\r" + nameofwave(current) + "- " + "\rFI: " + num2str(FI) + "\rspikes: " + num2str(spikes) + "\rcurrent injected: " + num2str(currentInjected)) return FI end
Thank you all so much for your input.
evaluates the righthand side once for each element of the destination range. Thus, in this example, FI is called once for each element in the layers dimension (because of [] at the end on the right) and prints each time it is called.
If you need further help, try creating a self-contained, simplified procedure that illustrates the problem and which we can execute.
December 24, 2015 at 12:25 pm - Permalink
to this:wName[DimSize(wName, 0) - 1][i][0]= FI(label, current)
and now it prints once per for loop iteration, which is what I wanted.Thanks for your help!
December 24, 2015 at 02:05 pm - Permalink
