Graphs exact same size and layout
Hi, I was wondering what is the standard procedure if I want to output multiple graphs in exact the same size and format -- the color bar position would be the same, the size of the graph would be the same as well as all the others? What is a good way to achieve this purpose? Thank you all!
Do you mean creating the same type of graph from different waves?
I like to write a function which sets the formatting. Use the ModifyAxis window etc. to change the graph to you likings, then copy and paste the commands into a function, e.g.:
//Make some data:
Make/O aa
SetScale/I x, 0, 2*pi, "", aa
aa= cos(x)
//create and format graph
function MakePlot(w)
    wave w
    // Display data
    Display/K=1 w
    // modify axis and marker
    ModifyGraph mode=3,marker=7
    ModifyGraph tick=2,mirror=1,minor=1,btLen=4,stLen=2
    // axis labels
    Label left "\\Z14 y-axis"
    Label bottom "\\Z14 x-axis"
    //Set size and margins
    ModifyGraph width=566.929,height=368.504
    ModifyGraph margin(left)=85,margin(bottom)=85
    //set annotation
    String name = NameOfWave(w)
    String AnnotationString
    sprintf AnnotationString, " Data:\r \\s(%s) %s ", name, name
    TextBox/C /N=NewText /S=3 /A=RB AnnotationString
    // set ColorScales etc
Thank you hrodstein, now I see where to look for this information, thank you! Helps a lot!
