DataFolder Programming, Movewave PathName help
I was hoping someone could help me with where I'm going wrong in this procedure.
I have a Parent Data Folder with maybe 9 or 10 subdatafolders inside it. (NOTE Parent data folder is itself a subfolder in something else.)
In each data folder there is a 2D wave which i would like to duplicate and then move the duplicate 2D wave to a new data folder that is located in the Parent Data Folder.
Fortunately I only have one 2D matrix in each subfolder beginning with a r so I can fileter it out using wavelist.
I wrote this to try and achieve this:
Function ExtractMatrices(ParentDF) DFREF ParentDF ListFolders() // function that returns a string of the folders contained in the ParentDataFolder similar to wavelist SVAR FolderListStr Variable numItems = ItemsInList(FolderListStr), i // counts how and indices the item broken by ; NewDataFolder/O ParentDF:Matrix_Copies for (i = 0; i<numItems; i+=1) // starts a loop to go through each name String DFname = StringFromList(i,FolderListStr,";") SetDataFolder DFname String findMatrix=Wavelist("r*",";","") String matrix= StringFromList(0,findMatrix,";") wave mat2D = $matrix String DuplicateWaveName= Nameofwave(mat2D)+"_D" duplicate/O mat2D, mat2D_D rename mat2D_D, $DuplicateWaveName movewave mat2D_D, :ParentDF:Matrix_Copies: SetDataFolder ParentDF endfor End
Problem 1) I don't think I've quite cracked the best way to reference a path name because when I first tried this function I accidentally had the arrow on the databrowser selecting a subfolder and the function would create the new folder in that data set ignoring what I had written.
Problem 2) Going deeper inside a datafolder seems simple enough but trying to step back out I am having problems. As when I run it I manage to duplicate the first wave but I can't extract it out.
I think i'm missing a few fundamental concepts here through lack of experience so if anyone can help that would be great!
Best wishes,
N
Here is a solution:
August 27, 2015 at 07:26 am - Permalink
