convolution terminology
Konstantinos Chatzipanagis
Assuming that we have a Raman envelope and we need to separate ovelapping peaks and then fit to define all necessary parameters (position,height,width). This process is traditionally called deconvolution. However, looking on terminology on internet i am not sure if this is the right term......Are we looking at the convolution of ovelapping peaks or the sum of these peaks? Maybe it is a matter of terminology here but i am a bit confused. Any ideas? I know for example that the voigt profile that can be used to fit one individual peak is the convolution of gaussian and lorentzian and not the sum of these 2. Nevertheless this is probably a different case since we are dealing with the fitting of one peak by using a combined fitting model (voigt), while in the first case i am talking about fitting 2 or more peaks of the actual spectrum (whether we use voigt profile for each peak or gaussian is another issue). I hope i have not confused things. Thank you
Depending on operators and functions you might apply chain rules, commutative rules, distributive rules etc. and readjust the point of view (e.g., to sums of convoluted functions instead of a convolution of a sum).
I use the terms "deconvolution" for reconstructed data and "curve decomposition" for fitted data.
Maybe you want to read:
https://en.wikipedia.org/wiki/Spectral_line_shape#Applications
https://en.wikipedia.org/wiki/Deconvolution
https://en.wikipedia.org/wiki/Curve_fitting
Hope it help,
HJ
July 17, 2015 at 08:20 am - Permalink
July 17, 2015 at 08:45 am - Permalink
Any other opinions?
HJ
July 17, 2015 at 09:01 am - Permalink
If you have a series of impulses (delta functions) that represent the intensity and location of a series of spectral lines, and a peak shape that represents what happens with various line-broadening processes, then the result can be viewed as a convolution of that peak shape with the series of impulses.
If you think about it, the integral that represents this convolution is really just a sum of peaks since the convolution of an impulse with a function is simply that function shifted and scaled. If you have two impulses, then you get a sum of two copies of the function, each shifted and scaled by the two impulses.
The fitting process (hopefully) gets you the locations and intensities as an output.
July 17, 2015 at 09:25 am - Permalink
July 17, 2015 at 10:07 am - Permalink
July 17, 2015 at 11:32 am - Permalink
* Peak fitting is a process where any number of well-defined component peaks are SUMMED to create a single envelope that should best fit the data.
* Convolution is a process where a true signal peak and its transmission function are INTEGRATED JOINTLY over the span of the signal peak to get a new measured signal peak.
* Deconvolution is a process where a true signal (peak) is pulled out of a measured signal (peak) that itself is a convolution of true signal * transmission function.
You are separating overlapping peaks by summing them individually to give a best fit to one peak. You are doing peak fitting not deconvolution.
On the other hand, I think that spectroscopists are generally allowed (albeit by their fellow spectroscopists) to use the term deconvolution to mean pulling out component peaks from a single peak.
Hence the confusion.
I would also note that I was once called out on a poster presentation at a national conference many years ago for using the term deconvolution of component peaks when I should have been saying peak fitting of component peaks.
July 17, 2015 at 06:51 pm - Permalink
July 18, 2015 at 03:17 am - Permalink
Good catch!
Line broadening functions in a comparable way to transmission function. It convolves the fundamental signal. I would probably be better to state it separately, as in ...
Convolution is the joint integration of a fundamental signal with a line-broadening process or an instrument transmission function.
OTOH, speaking somewhat jokingly, a delta function is only of real interest to a theoretician. All experimentalists realize they will never be able to measure one. So, most experimentalist never talk about their spectra as delta functions convolved with line-broadening. They just say they have a measured signal that is a convolution of the true signal with an instrument transmission function. Consider also that, in most cases of peak-fitting, the component peaks that are used to sum to an envelope peak are already line-broadened and transmission-function broadened because the measured peak is that way already. IOW, most (if not all) experimentalists do not try to "peak fit" delta functions convolved with line-broadening subsequently convolved with a transmission function.
July 21, 2015 at 06:43 am - Permalink
