Clearing Empty User Defined Hook Functions?
I have coding that essentially does the following:
    switch(how)
        case -1:    // clear all
            SetWindow $cw hook(MyHookA)=$""
            SetWindow $pn hook(MyHookA)=$""
            SetWindow $cw hook(MyHookB)=$""
            SetWindow $pn hook(MyHookB)=$""
            break
        case 0: // set A active
            SetWindow $cw hook(MyHookA)=MyHookAFunction
            SetWindow $pn hook(MyHookA)=MyHookAFunction
            break
        case 1: // set B active
            SetWindow $cw hook(MyHookB)=MyHookBFunction
            SetWindow $pn hook(MyHookB)=MyHookBFunction
            break
    endswitch
The hooks are attached to a panel that is external to a graph and to the graph. I notice, when I save the experiment and then reopen it, I get a compilation error. Essentially, the panel window recreation line contains code ...
      SetWindow kwTopWin, hook(MyHookA)=MyPanel#
      SetWindow kwTopWin, hook(MyHookB)=MyPanel#
This causes the experiment recreation to bomb.
So, how do I clear the user defined hooks and not leave empty traces of them in the window recreation macro for the experiment?
I think an answer is best arrived at by sending in an example experiment that demonstrates the problem to support@wavemetrics.com.
My initial bet is that there's a bug in how Igor fixes up hook function names in an independent module (is that what "MyPanel" is?
In other words, I suspect you really have
#pragma independentModule=MyPanel
You'll also help by pointing out which version of Igor you're using.
[quote=JimProuty]I think an answer is best arrived at by sending in an example experiment that demonstrates the problem to support@wavemetrics.com. ... [/quote]
Will do. Thanks!
[For the record, this turned out to be a bug in Igor 6 that'll be fixed for 6.11. The bug happens only in an independent module.]
