Is there a way to show more than just two cursors at a time ?
Default is show a cursor pair, either A & B or C & D. It would be handy to have 4 cursors available...
Any trick ?
...and in Igor 7 the info panel will be able to display info for all pairs at once (if you don't mind an info panel that might be pretty big!). Igor 7 is not quite yet in beta- see http://www.igorexchange.com/node/2004#comment-10377.
You may also use the command line:
display test
Cursor A test 20
Cursor B test 30
Cursor C test 40
Cursor D test 50
Cursor E test 60
Cursor F test 70
Calculations, e.g., distances, on the non-standard pairs have to be done manually afaik.
HJ
June 25, 2015 at 09:55 am - Permalink
June 25, 2015 at 10:10 am - Permalink
