concatenate files
For my analysis i will need to get a concatenated file of events from different imported files. I am using the Neuromatic 2.0 "import waves" command and one by one I am concatenating them.
Now my questions are:
- Do you know if there is a macro or procedure to concatenate and avoid the manual command and to avoid errors during the importation?
- I also wanted to ask if there is a way to show a continuous file of events sweeps by sweep and not just an episodic sets of events. I have a 90 sweeps file and I can only see them one by one but i would like to see them as a continuous file (90 all together or 3 by 3).
Thanks for your time
You will need to customize it for your purposes.
http://www.igorexchange.com/node/6409
April 7, 2015 at 09:09 am - Permalink
Still this is too hard for me to understand since this is my first attempt to programming.
Do you know where i can get more information about igor programming? I watched the introducing videos on their website and I am using the manual to help me but is not so simple for a newbie like me.
April 7, 2015 at 10:06 am - Permalink
IV-1: Working With Commands
IV-2: Programming Overview
IV-3: User-Defined Functions
You can find the same material in the help files by executing these commands:
The process of learning programming is:
1. Read
2. Experiment
3. Repeat from Step 1
April 7, 2015 at 10:51 am - Permalink
