Multiple Instances of Igor Pro on Windows
Can someone suggest the easiest way to implement two instances of Igor on the same windows7 machine. I would like to have the ability to select which of the igor pro instances that I use. Why? I have two well-developed Igor packages that seem to conflict with each other. I would simply like to have two different igor instances such that running one of them would only invoke one of the packages thereby eliminating any conflicts. Running the other igor instance would only call the second analysis package.
Thanks
March 14, 2015 at 03:09 pm - Permalink
