It's a particle size distribution experiment. The waves are given by the device as float, but when I load them in Igor they are taken as integer (I think it's because the device uses a comma instead of a dot for floats). I've discussed with my advisor and he said that it's ok like this.
But I'm wonder how could I get rid of the small steps and make it more "continuous".
I think your problem is you have too many data points for your resolution - the data increase stepwise with many points describing the steps. I suggest you try reducing the number of points you have and then running a simple smooth. For example:
Igor can handle comma as decimal separator. Choose Data->Load Waves->Load Waves. In the resulting dialog, set all options to taste. Click the Tweaks button and choose Comma from the decimal separator popup menu. Click Return and then Do It.
Hm... particle sizes... I have attached a copy of your experiment file with a LogNormal fit of the data. It's astonishingly good- is this fake data? :)
Anyway, I wouldn't alter the data- that's sort of like fraud, isn't it? But the fit is very good and the smooth fit curve can serve as a smooth representation of what the data is about. Just don't publish without saying that!
I have also attached a PNG picture of the graph so that everyone can see that it's a really good fit!
March 11, 2015 at 09:45 am - Permalink
Thanks in advance.
March 12, 2015 at 02:16 am - Permalink
Counts_Interpl_smth_dec[]=Counts_Interpl_smth[p*200]
Size_Interpl_smth_dec[]=Size_Interpl_smth[p*200]
Duplicate/O Counts_Interpl_smth_dec,Counts_Interpl_smth_dec_smth
Smooth 11, Counts_Interpl_smth_dec_smth
Hope this helps,
Kurt
March 12, 2015 at 03:12 am - Permalink
March 12, 2015 at 08:03 am - Permalink
March 12, 2015 at 01:13 pm - Permalink
P.S.: They are not fake data :D
March 17, 2015 at 08:38 am - Permalink
That was a bit unkind, wasn't it :)
March 18, 2015 at 10:07 am - Permalink
