Trouble with time wave
I have a folder of .txt files I want to load into a standard .pxp
The .txt time format is in am/pm (ex. 4:00 AM 4:01 AM... 4:00 PM). When I load using my function, it loads the times as the same regardless of am or pm. So 4:00 AM on 9/24 is seen the same as 4:00 PM (both loading as 04:00:00). I have attached a sample .txt and the code is below. The function is meant to load an entire folder so the .txt needs to be in its own folder to load. I have also sent this to the wavemetrics support. Any help is appreciated!
#pragma rtGlobals=3     // Use modern global access method and strict wave access.
Menu "Weather"
    "Load Weather Data...", LoadWeatherFiles("")
Function LoadWeatherFile(pathName, fileName, makeTable)
    String pathName     // Name of an Igor symbolic path or "".
    String fileName         // Name of file or full path to file.
    Variable makeTable      // 1 to make table, 0 to not make table
    // First get a valid reference to a file.
    if ((strlen(pathName)==0) || (strlen(fileName)==0))
        // Display dialog looking for file.
        Variable refNum
        Open/D/R/F="*.txt"/P=$pathName refNum as fileName
        fileName = S_fileName           // S_fileName is set by Open/D
        if (strlen(fileName) == 0)      // User cancelled?
            return -1
    // Now load the data. The /V flag specifies the accepted delimiters in the data file.
    // Add the /A flag if you don't want the "Loading Delimited Text" dialog.
    // Add the /O flag if you want to overwrite existing waves with the same names.
    // "Date" and "Time" are not available as wave names because they are Igor function names
    String columnInfoStr = " "
        columnInfoStr += "N='MET_TimeW',T=4;"
        columnInfoStr += "N='TimeW',F=7;"
        columnInfoStr += "N='Temp_C';"
        columnInfoStr += "N='_skip_';"
        columnInfoStr += "N='Hum_Per';"
        columnInfoStr += "N='Dew_Pt_C';"
        columnInfoStr += "N='Wind_Speed';"
        columnInfoStr += "N='Wind_Dir',F=-2;"
        columnInfoStr += "N='Wind_Chill_C';"
        columnInfoStr += "N='Heat_Index_C';"
        columnInfoStr += "N='THW_Index_C';"
        columnInfoStr += "N='Press_Bar';"
        columnInfoStr += "N='Precip_Inch';"
    String delimiters = "\t,"                       // Tab and comma-delimited
    String skipChars = "\" "                        // Skip quotes around date and time and spaces before commas
    LoadWave /J /L={0,2,0,0,0}/D/N /K=0 /V={delimiters,skipChars,0,0} /B=columnInfoStr /R={English, 1, 2, 1, 1, "Month/DayofMonth/Year", 40} /P=$pathName fileName
    Variable numWavesLoaded = V_flag            // V_flag is set by LoadWave
    if (numWavesLoaded != 12)
        Print "Error loading file - wrong number of waves loaded"
        return -1
    // Create reference to waves created by LoadWave
    Wave MET_TimeW,TimeW
    MET_timew += TimeW              // Add time to date to obtain date/time
    KillWaves/Z TimeW               // This is no longer needed
    return 0                            // Success
Function ConcatenateWeatherFile(pathName, fileName)
    String pathName
    String fileName
    // Create a new data folder
    NewDataFolder/O/S WeatherTemp
    Variable result = LoadWeatherFile(pathName, fileName, 0)
    SetDataFolder ::        // Back to original data folder
    if (result != 0)
        return result   // Error loading new waves
    // Concatenate new waves onto old
    Concatenate/NP {:WeatherTemp:MET_TimeW},MET_TimeW
    Concatenate/NP {:WeatherTemp:Temp_C},Temp_C
    Concatenate/NP {:WeatherTemp:Hum_Per},Hum_Per
    Concatenate/NP {:WeatherTemp:Dew_Pt_C},Dew_Pt_C
    Concatenate/NP {:WeatherTemp:Wind_Speed},Wind_Speed
    Concatenate/NP {:WeatherTemp:Wind_Dir},Wind_Dir
    Concatenate/NP {:WeatherTemp:Wind_Chill_C},Wind_Chill_C
    Concatenate/NP {:WeatherTemp:Heat_Index_C},Heat_Index_C
    Concatenate/NP {:WeatherTemp:THW_Index_C},THW_Index_C
    Concatenate/NP {:WeatherTemp:Press_Bar},Press_Bar
    Concatenate/NP {:WeatherTemp:Precip_Inch},Precip_Inch
    // Kill temp data folder
    KillDataFolder/Z :WeatherTemp
    return 0            // Success
Function LoadWeatherFiles(pathName)
    String pathName         // Name of symbolic path or "" to get dialog
    String fileName
    Variable index=0
    if (strlen(pathName)==0)            // If no path specified, create one
        NewPath/O temporaryPath         // This will put up a dialog
        if (V_flag != 0)
            return -1                       // User cancelled
        pathName = "temporaryPath"
    Variable result
    do          // Loop through each file in folder
        fileName = IndexedFile($pathName, index, ".txt")
        if (strlen(fileName) == 0)          // No more files?
            break                                   // Break out of loop
        result = ConcatenateWeatherFile(pathName, fileName)
        if (result == 0)                            // Did LoadAndGraph succeed?
                                                    // Print the graph.
            fileName = WinName(0, 1)                // Get the name of the top graph
            //String cmd
            //sprintf cmd, "PrintGraphs %s", fileName
            //Execute cmd                       // Explained below.
            //DoWindow/K $fileName          // Kill the graph
            //KillWaves/A/Z                 // Kill all unused waves
        index += 1
    while (1)
    if (Exists("temporaryPath"))            // Kill temp path if it exists
        KillPath temporaryPath
        Wave MET_TimeW,TimeW,Temp_C,Hum_Per,Dew_Pt_C,Wind_Speed,Wind_Dir,Wind_Chill_C,Heat_Index_C,THW_Index_C,Press_Bar,Precip_Inch
        Edit MET_TimeW,Temp_C,Hum_Per,Dew_Pt_C,Wind_Speed,Wind_Dir,Wind_Chill_C,Heat_Index_C,THW_Index_C,Press_Bar,Precip_Inch
        ModifyTable format(MET_TimeW)=8, width(MET_TimeW)=150
        Sort MET_TimeW Temp_C,Hum_Per,Dew_Pt_C,Wind_Speed,Wind_Dir;DelayUpdate
        Sort MET_TimeW Wind_Chill_C,Heat_Index_C,THW_Index_C,Press_Bar,Precip_Inch
        Sort MET_TimeW MET_TimeW
        DoWindow/K Weather
        DoWindow/C/T Weather,"Weather Data"
    return 0                        // Signifies success.
weatheroctmonth.txt (4.27 MB)
And LoadWeatherFiles is the last function (not to be confused with LoadWeatherFile in the singular, which is the first function).
Except that the time is NOT actually in am/pm format, it is in a/p format:
Date Time Out Temp Temp Hum Pt. Speed Dir Run Speed Dir Chill Index Index Index Bar Rain Rate Rad. Energy Rad. Index Dose UV D-D D-D Temp Hum Dew Heat EMC Density ET Samp Tx Recept Int. 10/02/13 11:56 p 8.2 8.2 8.2 97 7.8 0.4 SE 0.03 0.4 ESE 8.2 8.4 8.4 --- 1023.5 0.00 0.0 --- --- --- --- --- --- 0.007 0.000 13.9 73 9.2 13.6 14.18 1.2285 0.00 23 1 100.0 1
The second column has "11:56 p".
This isn't a format recognized by LoadWave. You may need to load the file using FReadLine and sscanf.
I have included below the code as I changed it to deal with "a" and "p". My changes are marked with "HR:".
Menu "Weather"
// HR:
// AMPMTimeAdjustment(theTime, flag)
// Returns the necessary adjustment in seconds to convert a time from AM/PM representation
// to 24 hour representation.
Function AMPMTimeAdjustment(theTime, flag)
    Variable theTime
    String flag                 // Must be either "a" or "p"
    Variable adjustment = 0
    Variable secondsIn12Hours = 43200
    if (CmpStr(flag, "a") == 0)
        // AM: If the hour is 12:xx, subtract seconds in 12 hours
        if (theTime >= secondsIn12Hours)
            adjustment = -secondsIn12Hours
        // PM: Adds 12 hours unless hour is 12:xx.
        if (theTime < secondsIn12Hours)
            adjustment = secondsIn12Hours
    return adjustment
        Variable refNum
            return -1
        columnInfoStr += "N='AMPM',F=-2;"           // HR: Load "a" or "p" after time into text wave
    delimiters += " "                               // HR: Add space - needed to load "a" and "p" into text wave
    if (numWavesLoaded != 13)                   // HR: 13 because of AMPM wave
        return -1
    // HR: Account for "a" for AM, "p" for PM
    // Add 12 hours where we have "p" unless hour is 12:xx
    // Subtract 12 hours where we have "a" if hour is 12:xx
    Wave/T AMPM
    TimeW += AMPMTimeAdjustment(TimeW, AMPM)
    KillWaves/Z AMPM                    // This is no longer needed
    return 0                            // Success
    String pathName
    String fileName
    if (result != 0)
    return 0            // Success
    String fileName
    Variable index=0
        if (V_flag != 0)
    Variable result
                                                    // Print the graph.
            //String cmd
        index += 1
    while (1)
        DoWindow/K Weather
Ahhh... I have been loading the .txt files into excel to view them, not a text editor. Sorry for the trouble. Thanks for the program edit.
