CurveFit/ODR=3 with weight crashes Igor - CPU dependency?
I've been fitting 2D data to implicit function.
CurveFit/ODR=3 keeps crashing Igor program when /XW flag is added.
But the worse problem is that the same code runs with no problem in other PC.
I tried three PCs - all on Windows 7 Enterprise for 64bit SP1 & Igor 6.2.2.2.
One laptop has AMD Turion 64 X2, two desktops have Intel core2 6700 / Intel core i5.
The last out of the three is the only which runs the code normally, and the other two gives problem.
And I suspect that the laptop has changed from normal to problematic during the last few days.
Because it fails to run the same code it run a few days ago.
The ODR package has CPU dependency? or is there anything I can check first in this case?
This drives me nuts..
If you can provide a simple example of the problem, please send an example with data and fit function to support@wavemetrics.com.
January 23, 2012 at 10:46 am - Permalink
January 30, 2015 at 04:52 am - Permalink
SaveExperiment
to reproduce it?Can you post the experiment?
January 30, 2015 at 09:56 am - Permalink
February 2, 2015 at 10:07 am - Permalink
February 2, 2015 at 01:46 pm - Permalink
