if an annotation is out of the window, how to get it back?
when I adjust the position of an annotation, i type a very large X,Y value which make the annotation out of the screen. In this case how to get it back?
One way is to make a recreation macro for the window, edit the coordinate of the annotation, and then rebuild the window.
Hop this helps,
Kurt
Hop this helps,
Kurt
em..., I will try this method. thank you.
johnweeks wrote:
pangeng wrote:
Q2
how to start a new row in the "create text" panel?
Use Igor 7.
7?7?7?????????I will check it out. thanks
