So Ive seen some scripts for doing this in imageJ, but Im terrible at java and I love the Igor environment, so I am curious how to go about doing it here, if its possible? Ive tried loading the files thru the various menu options, but the metadata waves get garbled every time so clearly I am doing it wrong so far.
Advice/tips much appreciated. Thanks.
EDIT: dm3 is a file format used by Gatan Digital Micrograph and are common in the microscopy world. Its basically a tiff with some metadata tucked in. I threw in an example file (its soot imaged with HRTEM if anybody is curious), need to rename it from .jpg to .dm3 as I couldnt upload it otherwise.44-82969s1-87000X.jpg(4.16 MB)
I'm interested in an answer to this. I can't offer any help except to say that BioFormats in ImageJ displays the metadata for the file. As you know, you can extract parts of that using a script, which we do for files in other microscopy formats. We tend to export this extraction to Igor, but it would be great to do it direct.
A quick look at the file suggests that it does not comply with TIFF standard (missing signature in the first few bytes) so perish the thought of using the ImageLoad operation to read these images. If you have sufficient information about the this file format you should be able to extract the relevant information using FBinRead (actually Open, FBinRead and Close).
You can open the file as a binary file and read it taking into consideration the binary file format (how the file was written). A link that I found describing the file format: http://www.er-c.org/cbb/info/dmformat/#dm3
I have knocked up a quick reader, based on the format description here (http://www.er-c.org/cbb/info/dmformat/#dm3) and here (http://rsb.info.nih.gov/ij/plugins/DM3Format.gj.html).
No guarantees that this is right.. but it should help you get something. Maybe someone can tidy up the code and make it more robust.
The meta data is put into a Notebook. I have suppressed the image data itself being put there.
Hope this helps,
Kurt
Code as follows:
#pragma rtGlobals=3// Use modern global access method and strict wave access.Function LoadDM3()// User selects DM3 file// opens DM3 file// starts to read data from the filevariable vRefNum
string sFileOpenMessage="Select a DM3 file"string sFileFilter="DM3 files (*.dm3):.dm3;All Files:.*.*;"Open/R/Z=2/F=sFileFilter/M=sFileOpenMessage vRefNum
// keep data from file openvariable vErr=V_flag
string sFullName=S_fileName
string sCleanFileName=CleanUpName(ParseFilePath(3, sFullName, ":", 0, 0),0)if(vErr == -1)return -1// User cancelled.endifif(vErr != 0)return vErr
endifvariable/G gvLayer=0// indent or nested group layervariable/G gvPrintData=1// =1 to allow printing of data, 0 to forbid (eg image data itself)NewNotebook/F=0/N=NBFileData
LoadDM3NBSetData("Loading data from "+sFullName)string sData
variable vData
// start reading data from the filedo// image file versionFBinRead/B=2/F=3 vRefNum,vData // big-endian, 4 bytesif(vData!=3)// should be 3
LoadDM3NBSetData("Error in file format (version)")breakendif// number of bytes in fileFBinRead/B=2/F=3 vRefNum,vData // big-endian, 4 bytesvariable vNumBytes = vData
LoadDM3NBSetData("Root tag directory size: "+num2str(vData))// byte order of tag dataFBinRead/B=2/F=3 vRefNum,vData // big-endian, 4 bytesvariable/G gvByteOrder // this will be the code in FBinRead/B=(gvByteOrder)if(vData==0)// big-endian
gvByteOrder=2
LoadDM3NBSetData("Data byte order: big-endian")elseif(vData==1)// little-endian
gvByteOrder=3
LoadDM3NBSetData("Data byte order: little-endian")else
LoadDM3NBSetData("Error in file format (byte order)")breakendif// Tag Group
LoadDM3TagGroup(vRefNum)breakwhile(1)FStatus vRefNum
if(V_flag!=0)// is validClose vRefNum // Close the file.endifreturn vErr // Zero signifies no error. EndFunction LoadDM3NBSetData(sData)string sData
NVAR gvLayer
NVAR gvPrintData
if(gvPrintData)
sData=padstring("",gvLayer*2,0x20)+sData+"\r"Notebook NBFileData setData=sData
endifEndFunction LoadDM3TagGroup(vRefNum)variable vRefNum
// loads a DM3 file Tag GroupNVAR gvLayer
variable vFlag
variable vData
gvLayer+=1// is this group sorted?FBinRead/F=1 vRefNum,vData // 1 bytevariable vGroupSorted
vGroupSorted=vData
LoadDM3NBSetData("Tag Group Sorted = "+num2str(vGroupSorted))// is this group open?FBinRead/F=1 vRefNum,vData // 1 bytevariable vGroupOpen
vGroupOpen=vData
LoadDM3NBSetData("Tag Group Open = "+num2str(vGroupOpen))// number of tags in groupFBinRead/B=2/F=3 vRefNum,vData // big-endian, 4 bytesvariable vNumTags
vNumTags=vData
LoadDM3NBSetData("Number of tags in this group = "+num2str(vNumTags))// tag entriesvariable vTags
for(vTags=0;vTags<vNumTags;vTags+=1)
vFlag=LoadDM3TagEntry(vRefNum)if(vFlag!=0)// had an errorreturn -1endifendfor// vTags
gvLayer-=1return0EndFunction LoadDM3TagEntry(vRefNum)variable vRefNum
// loads a DM3 file Tag EntryNVAR gvLayer
variable vFlag
variable vData
string sData
// Tag typeFBinRead/F=1 vRefNum,vData // 1 bytevariable vTagType
vTagType=vData // 21 = data, 20 = groupif(vTagType==21)// data - TagType
LoadDM3NBSetData("Tag type: 21 (Data)")elseif(vTagType==20)// Group
LoadDM3NBSetData("Tag type: 20 (Group)")elseif(vTagType==0)// end of file
LoadDM3NBSetData("End of file.")return -1else
LoadDM3NBSetData("Error: Tag type.")return -1endif// Tag label lengthFBinRead/B=2/F=2 vRefNum,vData // 2 bytesvariable vTagLabelLength
vTagLabelLength=vData
// Tag labelif(vTagLabelLength==0)// zero length
sData="_no label_"elseFReadLine/N=(vTagLabelLength) vRefNum, sData
LoadDM3NBSetData("Tag Label: "+sData)NVAR gvPrintData
if(cmpStr(sData,"Data")==0)
gvPrintData=0// forbid printing dataelse
gvPrintData=1// allow printing dataendif// Tag instanceif(vTagType==21)// data - TagType
vFlag=LoadDM3TagType(vRefNum)if(vFlag!=0)return -1endifelseif(vTagType==20)// Group
vFlag=LoadDM3TagGroup(vRefNum)// note: this is recursiveif(vFlag!=0)return -1endifendifreturn0EndFunction LoadDM3TagType(vRefNum)// tag datavariable vRefNum
string sData
variable vData
NVAR gvLayer
FReadLine/N=(4) vRefNum, sData
if(cmpstr(sData,"%%%%")!=0)
LoadDM3NBSetData("Error in Tag (expected %%%%).")return -1endif// length of encoded type definitionFBinRead/B=2/F=3 vRefNum,vData // 4 bytes// for a simple type this will = 1,// for a string this will = 2,// an array of a simple type will = 3,// structs have 1+2*f where f=number of fields in structvariable vDefinitionLength=vData
// encoded type infomake/FREE/O/I/N=(vDefinitionLength) wEncodingType // 4-byte waveFBinRead/B=2/F=3 vRefNum,wEncodingType
variable vIndex,vIndex2,vDataType,vSize
switch(vDefinitionLength)case1: // simple type
LoadDM3EncodedType(vRefNum,wEncodingType[0],wEncodingType)breakcase2: // string typeFBinRead/B=2/F=3 vRefNum,vData // 4 bytes
LoadDM3EncodedType(vRefNum,vData,wEncodingType)breakcase3: // array of simple type// wEncodingType[0]=20 - array// wEncodingType[1]= tag data type for array members// wEncodingType[2]= size of array
LoadDM3NBSetData("Array Data ("+num2str(wEncodingType[2])+")")for(vIndex=0;vIndex<wEncodingType[2];vIndex+=1)// loop round fields
LoadDM3EncodedType(vRefNum,wEncodingType[1],wEncodingType)endfor// vIndexbreak
default: // struct or array typeswitch(wEncodingType[0])case15: // struct type// wEncodingType[0]=15 - group// wEncodingType[1]=0 - usually// wEncodingType[2]= number fields// wEncodingType[3+field*2]= length field name =0// wEncodingType[4+field*2]= tag data type for value[field]
LoadDM3NBSetData("Struct Data ("+num2str(wEncodingType[2])+")")for(vIndex=0;vIndex<wEncodingType[2];vIndex+=1)// loop round fields
LoadDM3EncodedType(vRefNum,wEncodingType[4+vIndex*2],wEncodingType)endfor// vIndexbreakcase20: // array of structs type// wEncodingType[0]=20 - array// wEncodingType[1]=15 - group// wEncodingType[2]=0 - (group name) usually// wEncodingType[3]=number of entries in struct (field)// wEncodingType[4+field*2]= length field name =0// wEncodingType[5+field*2]= tag data type for value[field]// wEncodingType[...]// wEncodingType[last]= size of array (i.e. number of repeats of struct)
LoadDM3NBSetData("Array Data ("+num2str(wEncodingType[2])+")")for(vIndex2=0;vIndex2<wEncodingType[DimSize(wEncodingType,0)-1];vIndex2+=1)// loop round arrayfor(vIndex=0;vIndex<wEncodingType[3];vIndex+=1)// loop round fields
LoadDM3EncodedType(vRefNum,wEncodingType[5+vIndex*2],wEncodingType)endfor// vIndexendfor// vIndex2breakendSwitchendSwitchreturn0EndFunction LoadDM3EncodedType(vRefNum,vEncodingType,wEncodingType)variable vRefNum
variable vEncodingType
wave wEncodingType
variable vData, vIndex
string sData
NVAR gvByteOrder
NVAR gvLayer
switch(vEncodingType)case2: // shortFBinRead/B=(gvByteOrder)/f=2 vRefNum,vData
LoadDM3NBSetData("Short data: "+num2str(vData))breakcase3: // longFBinRead/B=(gvByteOrder)/f=3 vRefNum,vData
LoadDM3NBSetData("Long data: "+num2str(vData))breakcase4: // ushortFBinRead/B=(gvByteOrder)/f=2/U vRefNum,vData
LoadDM3NBSetData("UShort data: "+num2str(vData))breakcase5: // ulongFBinRead/B=(gvByteOrder)/f=3/U vRefNum,vData
LoadDM3NBSetData("ULong data: "+num2str(vData))breakcase6: // floatFBinRead/B=(gvByteOrder)/f=4 vRefNum,vData
LoadDM3NBSetData("Float data: "+num2str(vData))breakcase7: //doubleFBinRead/B=(gvByteOrder)/f=5 vRefNum,vData
LoadDM3NBSetData("Double data: "+num2str(vData))breakcase8: // booleanFBinRead/F=1 vRefNum,vData // 1 byte
LoadDM3NBSetData("Boolean data = "+num2str(vData))breakcase9: // charFReadLine/N=(1) vRefNum, sData
LoadDM3NBSetData("Char data = "+sData)breakcase10: // octetFBinRead/F=1 vRefNum,vData // 1 byte
LoadDM3NBSetData("Octet data = "+num2str(vData))breakcase15: // structbreakcase18: // stringfor(vIndex=0;vIndex<wEncodingType[1];vIndex+=1)// loop round string lengthFBinRead/B=(gvByteOrder)/f=2 vRefNum,vData
LoadDM3NBSetData("Unicode string data = "+num2str(vData)+ " ("+num2char(vData)+")")endforbreakcase20: // arraybreakendSwitchEnd
I had almost given up on this, and got distracted by work for some time, only to come back and find all this great help. I was otherwise looking at doing this manually for several hundred images (and that is just one week's work).
I love these forums, really.
EDIT: Acquisition time is given as the ushort data (all the meta data is provided in the raw format), I've decoded the following
0-9 = 48-57
: = 58
space = 32
P = 80
M = 77
A should follow from this to be equal to 65 (77 - 12)
Now to hijack this script so that it pulls this out from a group of files, translates it and writes it to a wave. Fun fun =)
All right, I got it running so that you select a folder, and then it will open each file, pull the time stamp, and put that data into a wave entry for easy use. Problem is just that it runs _real_ slow. I check to see if some of the metadata (like timestamps) had permanent positions in the .dm3 file, but no such luck. So I am forced to let the script read through the file piece by piece (with notebook disabled), until it finds the correct header, at which point it extracts the data.
Is it possible to search the entire open file for a specific string and then get that string position? This would be significantly faster, I imagine.
Here is the modified code if anybody wants to use it. Its ugly after I got done with it.
#pragma rtGlobals=3// Use modern global access method and strict wave access.//Notebook function now commented outFunction extract_timestamps()string list_dm3_files, prompt_alert,file_name
variable num_files
variable/G i//prompt for path to data foldernewpath/o dm3_data_folder
pathinfo dm3_data_folder
// load file names into string, sorting appropriately
list_dm3_files = IndexedFile(dm3_data_folder, -1, ".dm3")// Sort using combined alpha and numeric sort
list_dm3_files = SortList(list_dm3_files, ";", 16)//print list_dm3_files
num_files = itemsinlist(list_dm3_files)if(num_files == 0)
prompt_alert = "Could not find any DM3 data files in the chosen folder"doAlert0, prompt_alert
return0endif//make an output wave to store timestampsmake/o/d/n=(num_files) timestamps
// cycle through each file, one at a time for(i=0;i<num_files;i+=1)
file_name = stringfromlist(i,list_dm3_files)
LoadDM3(file_name)endforappendtotable timestamps
modifytable format(timestamps) = 7SetScale d 0,0,"dat", timestamps
EndFunction LoadDM3(file_name)string file_name
variable vRefNum
Open/R/Z=2/P=dm3_data_folder vRefNum as file_name
// User selects DM3 file// opens DM3 file// starts to read data from the file//variable vRefNum//string sFileOpenMessage="Select a DM3 file"//string sFileFilter="DM3 files (*.dm3):.dm3;All Files:.*.*;"//Open/R/Z=2/F=sFileFilter/M=sFileOpenMessage vRefNum// keep data from file open//variable vErr=V_flag//string sFullName=S_fileName//string sCleanFileName=CleanUpName(ParseFilePath(3, sFullName, ":", 0, 0),0)//if (vErr == -1)// return -1 // User cancelled.//endif//if (vErr != 0)// return vErr//endifvariable/G gvLayer=0// indent or nested group layervariable/G gvPrintData=1// =1 to allow printing of data, 0 to forbid (eg image data itself)//NewNotebook/F=0/N=NBFileData//LoadDM3NBSetData("Loading data from "+sFullName)string sData
variable vData
// start reading data from the filedo// image file versionFBinRead/B=2/F=3 vRefNum,vData // big-endian, 4 bytesif(vData!=3)// should be 3//LoadDM3NBSetData("Error in file format (version)")breakendif// number of bytes in fileFBinRead/B=2/F=3 vRefNum,vData // big-endian, 4 bytesvariable vNumBytes = vData
//LoadDM3NBSetData("Root tag directory size: "+num2str(vData))// byte order of tag dataFBinRead/B=2/F=3 vRefNum,vData // big-endian, 4 bytesvariable/G gvByteOrder // this will be the code in FBinRead/B=(gvByteOrder)if(vData==0)// big-endian
gvByteOrder=2//LoadDM3NBSetData("Data byte order: big-endian")elseif(vData==1)// little-endian
gvByteOrder=3//LoadDM3NBSetData("Data byte order: little-endian")else//LoadDM3NBSetData("Error in file format (byte order)")breakendif// Tag Group
NVAR gvLayer
NVAR gvPrintData
if(gvPrintData)
sData=padstring("",gvLayer*2,0x20)+sData+"\r"//Notebook NBFileData setData=sDataendifEndFunction LoadDM3TagGroup(vRefNum)variable vRefNum
variable vFlag
variable vData
vGroupSorted=vData
//LoadDM3NBSetData("Tag Group Sorted = "+num2str(vGroupSorted))// is this group open?FBinRead/F=1 vRefNum,vData // 1 bytevariable vGroupOpen
vGroupOpen=vData
//LoadDM3NBSetData("Tag Group Open = "+num2str(vGroupOpen))// number of tags in groupFBinRead/B=2/F=3 vRefNum,vData // big-endian, 4 bytesvariable vNumTags
vNumTags=vData
//LoadDM3NBSetData("Number of tags in this group = "+num2str(vNumTags))// tag entriesvariable vTags
variable vFlag
variable vData
string sData
vTagType=vData // 21 = data, 20 = groupif(vTagType==21)// data - TagType//LoadDM3NBSetData("Tag type: 21 (Data)")elseif(vTagType==20)// Group//LoadDM3NBSetData("Tag type: 20 (Group)")elseif(vTagType==0)// end of file//LoadDM3NBSetData("End of file.")return -1else//LoadDM3NBSetData("Error: Tag type.")return -1endif// Tag label lengthFBinRead/B=2/F=2 vRefNum,vData // 2 bytesvariable vTagLabelLength
endif// EDIT of original code, introducing case for exporting data directly into IGORif(cmpStr(sData, "Acquisition Time")==0)//read 5x to move to correct positionFReadLine/N=(4) vRefNum, sData
//read actual timestamp datawave timestamps
Nvar gvByteOrder,ivariable byte_num,hours,minutes,seconds,total_seconds
variable timestampLength
string timepiece
string timestamp
FBinRead/B=(gvByteOrder)/f=2/U vRefNum, vData // read the first piece//print vData
vData -= 48// translates from unsigned short data format
timepiece = num2str(vData)
timestamp = timepiece
FBinRead/B=(gvByteOrder)/f=2/U vRefNum, vData // read the second piece//print vData
vData -= 48if(vData != 10)// check for the semi-colon and describe length of stamp
timestampLength = 6else
timepiece = ":"
timestampLength = 5endif
timestamp = timestamp + timepiece
for(byte_num=0;byte_num<timestampLength;byte_num+=1)FBinRead/B=(gvByteOrder)/f=2/U vRefNum, vData // read the rest of it//print vData
timepiece = num2str(vData)else
timepiece = ":"endif
endforprint"The timestamp is :", timestamp
hours = str2num(StringFromList(0, timestamp ,":"))// set 1 pm - 7 pm to military hoursif(hours <8)
hours += 12endif
total_seconds = hours *3600
minutes = str2num(StringFromList(1,timestamp,":"))
total_seconds += minutes*60
seconds = str2num(StringFromList(2,timestamp,":"))
total_seconds += seconds
timestamps[i] = total_seconds
// continue with normal codeelse
vFlag=LoadDM3TagGroup(vRefNum)// note: this is recursiveif(vFlag!=0)return -1endifendifendif// End of the introduced case see abovereturn0EndFunction LoadDM3TagType(vRefNum)// tag datavariable vRefNum
string sData
variable vData
NVAR gvLayer
if(cmpstr(sData,"%%%%")!=0)//LoadDM3NBSetData("Error in Tag (expected %%%%).")return -1endif// length of encoded type definitionFBinRead/B=2/F=3 vRefNum,vData // 4 bytes// for a simple type this will = 1,// for a string this will = 2,// an array of a simple type will = 3,// structs have 1+2*f where f=number of fields in structvariable vDefinitionLength=vData
LoadDM3EncodedType(vRefNum,vData,wEncodingType)breakcase3: // array of simple type// wEncodingType[0]=20 - array// wEncodingType[1]= tag data type for array members// wEncodingType[2]= size of array//LoadDM3NBSetData("Array Data ("+num2str(wEncodingType[2])+")")for(vIndex=0;vIndex<wEncodingType[2];vIndex+=1)// loop round fields
default: // struct or array typeswitch(wEncodingType[0])case15: // struct type// wEncodingType[0]=15 - group// wEncodingType[1]=0 - usually// wEncodingType[2]= number fields// wEncodingType[3+field*2]= length field name =0// wEncodingType[4+field*2]= tag data type for value[field]//LoadDM3NBSetData("Struct Data ("+num2str(wEncodingType[2])+")")for(vIndex=0;vIndex<wEncodingType[2];vIndex+=1)// loop round fields
LoadDM3EncodedType(vRefNum,wEncodingType[4+vIndex*2],wEncodingType)endfor// vIndexbreakcase20: // array of structs type// wEncodingType[0]=20 - array// wEncodingType[1]=15 - group// wEncodingType[2]=0 - (group name) usually// wEncodingType[3]=number of entries in struct (field)// wEncodingType[4+field*2]= length field name =0// wEncodingType[5+field*2]= tag data type for value[field]// wEncodingType[...]// wEncodingType[last]= size of array (i.e. number of repeats of struct)//LoadDM3NBSetData("Array Data ("+num2str(wEncodingType[2])+")")for(vIndex2=0;vIndex2<wEncodingType[DimSize(wEncodingType,0)-1];vIndex2+=1)// loop round arrayfor(vIndex=0;vIndex<wEncodingType[3];vIndex+=1)// loop round fields
wave wEncodingType
string sData
NVAR gvByteOrder
NVAR gvLayer
//LoadDM3NBSetData("Short data: "+num2str(vData))breakcase3: // longFBinRead/B=(gvByteOrder)/f=3 vRefNum,vData
//LoadDM3NBSetData("Long data: "+num2str(vData))breakcase4: // ushortFBinRead/B=(gvByteOrder)/f=2/U vRefNum,vData
//LoadDM3NBSetData("UShort data: "+num2str(vData))breakcase5: // ulongFBinRead/B=(gvByteOrder)/f=3/U vRefNum,vData
//LoadDM3NBSetData("ULong data: "+num2str(vData))breakcase6: // floatFBinRead/B=(gvByteOrder)/f=4 vRefNum,vData
//LoadDM3NBSetData("Float data: "+num2str(vData))breakcase7: //doubleFBinRead/B=(gvByteOrder)/f=5 vRefNum,vData
//LoadDM3NBSetData("Double data: "+num2str(vData))breakcase8: // booleanFBinRead/F=1 vRefNum,vData // 1 byte//LoadDM3NBSetData("Boolean data = "+num2str(vData))breakcase9: // charFReadLine/N=(1) vRefNum, sData
//LoadDM3NBSetData("Char data = "+sData)breakcase10: // octetFBinRead/F=1 vRefNum,vData // 1 byte//LoadDM3NBSetData("Octet data = "+num2str(vData))breakcase15: // structbreakcase18: // stringfor(vIndex=0;vIndex<wEncodingType[1];vIndex+=1)// loop round string lengthFBinRead/B=(gvByteOrder)/f=2 vRefNum,vData
//LoadDM3NBSetData("Unicode string data = "+num2str(vData)+ " ("+num2char(vData)+")")endforbreakcase20: // arraybreakendSwitchEnd
[quote=daggaz]
[/quote]
Just a thought - you could use FStatus to find the length of the file, then use PadString and FBinRead to read the entire file into a string variable. Then finally search this for your specific string using strsearch.
I don't know whether this would be faster.
HTH,
Kurt
Here igor always complains with "out of memory" if I try to load your file (renamed to tiff before).
November 20, 2014 at 03:51 am - Permalink
November 20, 2014 at 04:59 am - Permalink
November 20, 2014 at 12:45 pm - Permalink
November 21, 2014 at 12:31 am - Permalink
Hope this helps,
Kurt
Code as follows:
November 21, 2014 at 01:16 am - Permalink
0-9 = 48-57
: = 58
space = 32
P = 80
M = 77
May 5, 2015 at 05:20 am - Permalink
May 13, 2015 at 05:44 am - Permalink
[/quote]
FStatusto find the length of the file, then usePadStringandFBinReadto read the entire file into a string variable. Then finally search this for your specific string usingstrsearch.I don't know whether this would be faster.
HTH,
Kurt
May 13, 2015 at 11:43 pm - Permalink
May 18, 2015 at 12:13 am - Permalink
