Odd Behavior Returns NaN - Bug??
rtn2 = -(((2*kR - 1)*exp(2*kR)+1)*exp(-2*kR)*ksq*exp(-2*kappa*z))/4
I am getting something very odd in behavior and wondered if someone might check behind for me. Here is a debug report.
print z, kR, ksq, kappa, rtn2 --- 0.006 316.228 115.849 31.6228 -12513.3 0.006 398.107 115.849 39.8107 NaN print -(((2*398 - 1)*exp(2*398)+1)*exp(-2*398)*116*exp(-2*39.8*0.006))/4 NaN
I set up the function in Maple and get this ...
frtn2:=proc(kR,ksq,ka,z) .... --- evalf(frtn2(316, 116, 31.6, 0.006)) = -12523.99512 evalf(frtn2(398, 116, 39.8, 0.006)) = -14300.33074
I find the behavior as a return NaN very confusing.
Igor 6.35A on Mac 10.9.5.
The largest floating-point exponent in IEEE double-precision floating point is 307.95 ( 2^1023).
Since your exponent (345.7) exceeds the IEEE max, I would expect some kind of error.
November 9, 2014 at 08:49 am - Permalink
I will have to find a clever way around this. Or perhaps the orders of magnitudes on my inputs are ... way off.
November 9, 2014 at 09:25 am - Permalink
I simply multiplied your first two exponential parenthetical expressions. Apparently underflow is not an issue. Note also that the Maple result was obtained, presumably because of some symbolic pre-manipulation.
Is there an intentional discrepancy between your early arguments (398) and the final one (39.8) ?
November 9, 2014 at 10:39 am - Permalink
After that, I have an approximation that can take over (basically, it is the limit of the exact expression as kR --> infinity)
This would make an interesting assignment for an course on numerical methods and computer tools ... "Examples of When Your Computer Programming Tool is Not God". Good thing I had some 8 bit Fortran programming experience in my background to understand the history behind the limitation here. :-)
Much obliged for the quick response on a Sunday night!
November 9, 2014 at 07:12 pm - Permalink
