Passing waves for user defined fit function
Is it possible? and How?
No, AFAIK this is not possible. See DisplayHelpTopic "User-Defined Fitting Function: Detailed Description" for the details.
Is the standard solution a la
Function F(w, x) : FitFunc
    WAVE w
        Variable x
        Wave root:myWave // additional wave
    <body of function>
    <return statement>
not viable for you?
It is possible using a structure fit function. But they are difficult to use- structures can only exist inside a user-defined function, so FuncFit has to be called from within a driver function.
Otherwise, use the solution proposed by thomas_braun.
