Convert text wave into numeric wave and vice versa
// Handy Function to convert numeric waves into text waves Function ConvertNumWvToTxtWv(W) Wave W Variable np = numpnts(W) Make /T /O /N=(np) TxtConvert Variable x for(x=0;x<np;x+=1) TxtConvert[x] = num2str(W[x]) endfor End // Handy Function to convert text waves into numeric waves Function ConvertTxtWvToNumWv(W) Wave /T W Variable np = numpnts(W) Make /O /N=(np) NumConvert Variable x for(x=0;x<np;x+=1) NumConvert[x] = str2num(W[x]) endfor End
August 28, 2014 at 04:10 am - Permalink
We don't need a function:
July 21, 2025 at 01:46 pm - Permalink
Note that this is generally not such a good idea, since there is the possibility to loose precision on the way (especially when using num2str()). See:
You would at least want to control the precision, which can be done from Igor 9 onward using an optional formatStr.
July 21, 2025 at 11:38 pm - Permalink
