category plot legend with bar stroke
I'm using igorpro 6.34A on a mac to make category plot. I use a color table (rainbow16) to color the bars and then add legends for each bar. What I find is that when I choose to use bar stroke (black), the legends will all be the color (all black) of the bar stroke color instead of the color table, while the fill-in of each bar still use the color table I choose. One way, I think, to correct this is to stack another graph, but is there other ways for this?
You can select the style of one point of the trace using something like:
Legend "\\s(mywave[3]) symbol drawn at point 3"
instead of the usual:
Legend "\\s(mywave) symbol drawn at point 0"
[quote=JimProuty]You can select the style of one point of the trace using something like:
Jim, this is what I'm doing. It works without Bar Stroke, but select Bar Stroke all the legends is the same then.
[quote=wwzhang2]
Jim, this is what I'm doing. It works without Bar Stroke, but select Bar Stroke all the legends is the same then.[/quote]
Make sure your Legend's "Symbol Min Thickness" is a small number, like 1. If it is too large, the legend marker stroke will overprint the fill.
[quote=JimProuty][quote=wwzhang2]
Software Engineer, WaveMetrics, Inc.[/quote]
I still can't make it work. I attach an example for the problem.
thanks
bar.pxp (41.85 KB)
Turn off the bar stroke to allow the current versions of Igor to draw the filled bar color in the legend.
Or (if you are brave) download the "nightly build" which will have this bug fixed tonight (so download tomorrow).
http://www.wavemetrics.net/Downloads/latest
[quote=JimProuty]Turn off the bar stroke to allow the current versions of Igor to draw the filled bar color in the legend.
Thank you
