Tektronix Query File Loader
// Tek Query File Loader
// This code was written to load a Tektronix Query File which is a dump of a query to a Tek scope.
// NOTE: This is not the Tek WFM file format.
// The way to determine the header length is to look for the ":CURVE" keyword. It is formatted like this:
//      ":CURVE <digit><number>"        .e.g., ":CURVE 41000"
// where <digit> represents the number of digits is the following number and <number> represents the number of
// samples of binary data that follow. In this case, "4" is the number of digits in "1000" and 1000 is the number of samples.
static Constant kHeaderLength = 282             // Length of header in bytes. Empirically determined.
static Constant kWaveDataType = 2               // Single precision floating point
//  LoadTekQueryFile(pathName, fileName, createTable, createGraph)
//  pathName is the name of an Igor symbolic path or "".
//  fileName is one of the following:
//      The name of a file in the folder designated by pathName.
//      A partial path from the folder designated by pathName to the file to be loaded.
//      A full path to the file to be loaded.
//      "" to get an Open File dialog.
// Add an item to Igor's Load Waves submenu (Data menu)
Menu "Load Waves"
    "Load Tek Query File...", LoadTekQueryFileMenuItem()
    "Load All Tek Query Files In Folder...", LoadAllTekQueryFiles("", "", 0, 0)
Function/S StripDoubleQuotes(str)
    String str                  // A string starting and ending with double quotes
    if (CmpStr(str[0], "\"") != 0)
        return str              // String did not start with double quotes
    Variable len  = strlen(str)
    str = str[1,len-2]
    return str
Structure TekQueryHeaderInfo
    Variable encoding           // 0 = binary. -1 = unknown. Currently the only encoding I know about is binary. From ENCDG keyword.
    Variable byteOrder          // 0 = big-endian, 1 = little-endian.  From BYT_OR keyword.
    Variable dataType           // See WaveType for possible values. From BIT_NR and BN_FMT keywords.
    Variable numPoints          // Number of points in waveform. From NR_PT keyword.
    String xUnits               // From XUNIT keyword.
    Variable x0                 // From XZERO keyword.
    Variable dx                 // From XINCR keyword.
    String yUnits               // From YUNIT keyword.
    Variable yOffset                // From YOFF keyword.
    Variable yZero              // From YZERO keyword.
    Variable yMultiplier        // From YMULT keyword.
EndStructure
Function ExtractQueryHeaderInfo(refNum, headerInfo, quiet)
    Variable refNum         // File reference number
    STRUCT TekQueryHeaderInfo &headerInfo
    Variable quiet              // 0 - print information about errors
    Variable result = 0
    Variable originalPos
    FStatus refNum
    originalPos = V_filePos
    // Read header string
    String headerStr = ""
    Variable headerStrLength = kHeaderLength
    FSetPos refNum, 0
    headerStr = PadString(headerStr, kHeaderLength, 0x20)
    FBinRead refNum, headerStr
    FSetPos refNum, originalPos
    // Parse header string
    String str
    str = StringByKey("ENCDG", headerStr, " ")
    strswitch(str)
        case "BIN":
            headerInfo.encoding = 0
            break
        default:
            headerInfo.encoding = -1            // Unknown encoding
            result -= 1
            break
    endswitch
    str = StringByKey("BYT_OR", headerStr, " ")
    strswitch(str)
        case "MSB":
            headerInfo.byteOrder = 0
            break
        case "LSB":
            headerInfo.byteOrder = 1
            break
        default:
            headerInfo.byteOrder = -1           // Unknown byte order
            result -= 1
            break
    endswitch
    headerInfo.numPoints = NumberByKey("NR_PT", headerStr, " ")
    headerInfo.xUnits = StripDoubleQuotes(StringByKey("XUNIT", headerStr, " "))
    headerInfo.x0 = NumberByKey("XZERO", headerStr, " ")
    headerInfo.dx = NumberByKey("XINCR", headerStr, " ")
    headerInfo.yUnits = StripDoubleQuotes(StringByKey("YUNIT", headerStr, " "))
    headerInfo.yOffset = NumberByKey("YOFF", headerStr, " ")
    headerInfo.yZero = NumberByKey("YZERO", headerStr, " ")
    headerInfo.yMultiplier = NumberByKey("YMULT", headerStr, " ")
    Variable numBitsPerPoint = NumberByKey("BIT_NR", headerStr, " ")
    String binaryFormat = StringByKey("BN_FMT", headerStr, " ")
    strswitch(binaryFormat)
        case "RI":                              // Presumably "real integer"
            switch (numBitsPerPoint)
                case 8:
                    headerInfo.dataType = 8     // 8 bit signed integer
                    break
                case 16:
                    headerInfo.dataType = 16    // 16 bit signed integer
                    break
                case 32:
                    headerInfo.dataType = 32    // 32 bit signed integer
                    break
                default:
                    headerInfo.dataType = -1    // Unknown type
                    result -= 1
                    break
            endswitch
            break
        default:
            headerInfo.dataType = -1            // Don't understand datatype
            result -= 1
            break
    endswitch
    return result
//  LoadTekQueryFileDialog(createTable, createGraph)
//  Displays a dialog in which the user can enter parameters.
//  All of the parameters function both as inputs, to preset the dialog values,
//  and as output, to return the values to the calling routine.
//  The function result is 0 if OK or -1 if cancel.
Function LoadTekQueryFileDialog(createTable, createGraph)
    Variable &createTable               // Input and output.
    Variable &createGraph               // Input and output.
    if ( (createTable<1) || (createTable>2) )
        createTable = 1
    if ( (createGraph<1) || (createGraph>2) )
        createGraph = 1
    // This is necessary because you can't pass an & parameter to Prompt.
    Variable createTable2 = createTable
    Variable createGraph2 = createGraph
    Prompt createTable2, "Create table", popup "Yes;No"
    Prompt createGraph2, "Create graph", popup "Yes;No"
    DoPrompt "Load Tek Query File", createTable2, createGraph2
    if (V_Flag != 0)
        return -1           // User cancelled.
    createTable = createTable2
    createGraph = createGraph2
Function LoadTekQueryFile(pathName, fileName, createTable, createGraph, quiet, newWaveName)
    String pathName         // Igor symbolic path name or "" for dialog.
    String fileName             // file name, partial path and file name, or full path or "" for dialog.
    Variable createTable        // 1 = Yes, 2 = No, 0 for dialog.
    Variable createGraph        // 1 = Yes, 2 = No, 0 for dialog.
    Variable quiet              // 0 = print diagnostic and error messages, 1 = print error messages only, 2 = do not print diagnostic or error messages
    String &newWaveName     // Output: Name of wave created.
    newWaveName  = ""
    Variable err
    if ( (createTable==0) || (createGraph==0) )
        err = LoadTekQueryFileDialog(createTable, createGraph)
        if (err != 0)
            return err
    // This puts up a dialog if the pathName and fileName do not specify a file.
    String message = "Select a Tek Query file"
    Variable refNum
    Open /R /Z=2 /P=$pathName /T="????" /M=message refNum as fileName   // /T flag presents "All files" in Open File dialog.
    // Save outputs from Open in a safe place.
    err = V_Flag
    String fullPath = S_fileName
    if (err != 0)
        return err          // -1 means user canceled.
    // Load the header information
    STRUCT TekQueryHeaderInfo headerInfo
    if (ExtractQueryHeaderInfo(refNum, headerInfo, quiet!=2) != 0)
        if (quiet != 2)
            Print "Error while loading header section of the file."
        Close refNum
        return -1
    Close refNum
    switch (headerInfo.encoding)
        case 0:                             // Binary
            break
        default:
            if (quiet != 2)
                Print "The file's encoding is unknown. Only binary encoding is supported."
            return -1
    endswitch
    if (quiet == 0)
        Printf "Loading Tek Query data from \"%s\"\r", fullPath
    GBLoadWave /B=(headerInfo.byteOrder) /A=tekWave /T={headerInfo.dataType,kWaveDataType} /S=(kHeaderLength) /W=1 /U=(headerInfo.numPoints) /Q fullPath
    if (V_flag == 0)
        if (quiet != 2)
            Print "Error while loading binary data section of the file."
        return -1
    newWaveName = StringFromList(0, S_waveNames)
    Wave w = $newWaveName
    SetScale/P x, headerInfo.x0, headerInfo.dx, ""+headerInfo.xUnits, w
    SetScale d, 0, 0, ""+headerInfo.yUnits, w
    // I don't know what headerInfo.yZero is all about (YZERO keyword).
    w = (w - headerInfo.yOffset) * headerInfo.yMultiplier
    if (quiet == 0)
        Printf "Created wave %s, %d points.\r", newWaveName, numpnts(w)
    if (createTable == 1)
        Edit w.id
        ModifyTable format[1]=3,digits[1]=9     // Display time in suitable format.
    if (createGraph == 1)
        Display w
    return 0            // Zero signifies no error.
Function LoadTekQueryFileMenuItem()
    String newWaveName
    LoadTekQueryFile("", "", 1, 1, 0, newWaveName)
//  LoadAllTekQueryFilesDialog(extension, createTable, createGraph)
Function LoadAllTekQueryFilesDialog(extension, createTable, createGraph)
    String &extension                   // Input and output
    if (CmpStr(extension,".wfm")!=0 && CmpStr(extension,"????")!=0)
        extension = ".wfm"              // .wfm is really the wrong extension for a Tek Query file
        createTable = 1
        createGraph = 1
    String extension2 = extension
    Prompt extension2, "Tek Query file name extension", popup ".wfm;Any extension"
    DoPrompt "Load All Tek Query Files", extension2, createTable2, createGraph2
    if (V_Flag != 0)
    if (CmpStr(extension2, "Any extension") == 0)
        extension2 = "????"
    extension = extension2
Function LoadAllTekQueryFiles(pathName, extension, createTable, createGraph)
    String pathName         // Name of an Igor symbolic folder created by Misc->NewPath
    String extension            // e.g., ".wfm". Pass "????" for any extension. Pass "" for dialog.
    if (CmpStr(extension,"")==0 || createTable<1 || createTable>2 || createGraph<1 || createGraph>2)
        if (LoadAllTekQueryFilesDialog(extension, createTable, createGraph) != 0)
    if (strlen(pathName) == 0)
        String message
        if (CmpStr(extension, "????") == 0)
            message = "Select a directory containing Tek Query files with any extension"
            sprintf message, "Select a directory containing Tek Query files with %s extension", extension
        NewPath/O/M=message TekQueryDataPath        // This displays a dialog in which you can select a folder
        if (V_flag != 0)
            return V_flag                               // -1 means user canceled
        pathName = "TekQueryDataPath"
    Variable err = 0
    String newWaveName
    String fileName
    Variable i = 0
    do
        fileName = IndexedFile($pathName, i, extension)
        if (strlen(fileName) == 0)
            break                                       // No more files
        err = LoadTekQueryFile(pathName, fileName, 2, 2, 1, newWaveName)
        if (err != 0)
            return err
            if (i == 0)
                Edit $newWaveName
                AppendToTable $newWaveName
            if (i == 0)
                Display $newWaveName
                AppendToGraph $newWaveName
        i += 1
    while(1)
