Panel Control to Draw or Edit Marker Waves
This uses a panel to create, edit, and clear a drawing wave. The waves are created in the current data folder and have the names drawwaveY and drawwaveX.
// a static constant to set the panel name StrConstant k_panelname = "WaveDrawEdit" // change this to set your desired marker style to create and edit the marker wave Function set_DrawMarkerStyle(frontimgwin) string frontimgwin // set your desired marker style here ModifyGraph/W=$frontimgwin mode=3,marker=8,msize=5,mrkThick=2 return 0 end // call this to create the panel Function show_DrawControlPanel() : Panel NewPanel/W=(50,50,250,100)/N=$k_panelname as "Wave Draw/Edit" ModifyPanel/W=$k_panelname fixedSize=1,noEdit=1 Button bDrawControl,pos={15,10},size={50,20}, fSize=14, userdata(draw)="start",proc=ButtonProc,title="Start" Button bEdit,pos={70,10},size={50,20},fSize=14,proc=ButtonProc,title="Edit",disable=2 Button bClear,pos={130,10},size={50,20},fSize=14,proc=ButtonProc,title="Clear",disable=2 return 0 end // do or end the drawing or editing Function do_Draw() string udata, frontimgwin udata = GetUserData(k_panelname,"bDrawControl","draw") frontimgwin = WinName(0,1,1) strswitch(udata) case "start": Button bDrawControl, win=$k_panelname, userdata(draw)="end", title="End..." Button bEdit, win=$k_panelname, disable=2 Button bClear, win=$k_panelname, disable=2 // the drawing waves are created in the current data folder make/N=0/O drawwaveX, drawwaveY SetDrawLayer/W=$frontimgwin ProgFront GraphWaveDraw/W=$frontimgwin/L/T/O drawwaveY, drawwaveX set_DrawMarkerStyle(frontimgwin) break case "end": GraphWaveEdit/W=$frontimgwin/T=1 drawwaveY GraphNormal/W=$frontimgwin SetDrawLayer/W=$frontimgwin UserFront Button bDrawControl, win=$k_panelname, userdata(draw)="start", title="Start" Button bEdit, win=$k_panelname, disable=0 Button bClear, win=$k_panelname, disable=0 break endswitch return 0 end // edit the drawing Function do_Edit() string frontimgwin = WinName(0,1,1) Button bDrawControl, win=$k_panelname, userdata(draw)="end", title="End..." Button bEdit, win=$k_panelname, disable=2 Button bClear, win=$k_panelname, disable=2 SetDrawLayer/W=$frontimgwin ProgFront GraphWaveEdit/T=1/W=$frontimgwin drawwaveY return 0 end // clear the drawing Function do_Clear() string frontimgwin = WinName(0,1,1) GraphNormal/W=$frontimgwin SetDrawLayer/W=$frontimgwin UserFront RemoveFromGraph/W=$frontimgwin/Z drawwaveY Button bEdit, win=$k_panelname, disable=2 Button bClear, win=$k_panelname, disable=2 return 0 end // button control Function ButtonProc(ba) : ButtonControl STRUCT WMButtonAction &ba switch( ba.eventCode ) case 2: // mouse up strswitch(ba.ctrlName) case "bDrawControl": do_draw() break case "bEdit": do_edit() break case "bClear": do_clear() break endswitch break case -1: // control being killed break endswitch return 0 end
With one clever change, the system now keeps the markers for the drawing also when clicking the End... button. It first toggles to GraphWaveEdit/T=1, then toggles to GraphNormal.
April 24, 2020 at 08:43 am - Permalink
