Get the color of a trace on a graph
Make test Display test print GetTraceColor("Graph0", "test") 65535,0,0 ModifyGraph rgb=(0,0,39168) print GetTraceColor("Graph0", "test") 0,0,39168
//** // Get the RGB triplet representing the color of a trace on a graph. // // @param graphName // A string containing the name of the graph. // @param traceName // A string containing the name of the trace. // @return // A string containing a comma separated list with the red, green, // and blue numeric values of the specified trace, or if there was // an error an empty string will be returned. //* Function/S GetTraceColor(graphName, traceName) String graphName String traceName if (WinType(graphName) != 1) printf "There is not a graph named %s.\r", graphName return "" endif String info = TraceInfo(graphName, traceName, 0) if (strlen(info) <= 0) printf "There is not a trace named %s on graph %s.\r", traceName, graphName return "" endif String traceRecreation = info[strsearch(info, "RECREATION", 1), strlen(info) - 1] String traceColors = StringByKey("rgb(x)", traceRecreation, "=", ";") // Remove parenthesis from string. traceColors = RemoveEnding(traceColors[1, strlen(traceColors) - 1], ")") return traceColors End
