Finding the First Line of Data in a Plain Text Data File
// This snippet illustrates how to load data from a text file when there is a variable
// length header before the data. The technique is to read the file line-by-line
// using FReadLine, looking for the first data line. In this case the header ends
// with a line that starts like this:
//  "[DATA...]
// We look for that pattern to identify where the data starts.
Function FindFirstDataLine(pathName, filePath)
    String pathName     // Name of symbolic path or ""
    String filePath         // Name of file or partial path relative to symbolic path.
    Variable refNum
    Open/R/P=$pathName refNum as filePath
    String buffer, text
    Variable line = 0
    do
        FReadLine refNum, buffer
        if (strlen(buffer) == 0)
            Close refNum
            return -1                       // The expected keyword was not found in the file
        text = buffer[0,4]
        if (CmpStr(text, "[DATA") == 0)     // Line does start with "[DATA" ?
            Close refNum
            return line + 1                 // Success: The next line is the first data line.
        line += 1
    while(1)
    return -1       // We will never get here
Function LoadDataFile(pathName, filePath, extension)
    String pathName     // Name of symbolic path or "" to display dialog.
    String filePath         // Name of file or "" to display dialog. Can also be full or partial path relative to symbolic path.
    String extension            // e.g., ".dat" for .dat files. "????" for all files.
    Variable refNum
    // Possibly display Open File dialog.
    if ((strlen(pathName)==0) || (strlen(filePath)==0))
        Open /D /R /P=$pathName /T=(extension) refNum as filePath
        filePath = S_fileName           // S_fileName is set by Open/D
        if (strlen(filePath) == 0)      // User cancelled?
            return -1
        // filePath is now a full path to the file.
    Variable firstDataLine = FindFirstDataLine(pathName, filePath)
    if (firstDataLine < 0)
        Printf "No data found in file %s\r", filePath
        return -1
    LoadWave /J /D /O /E=1 /K=0 /L={0,firstDataLine,0,0,0} /P=$pathName filePath
