Chi2 map - calculate chi2 as a parameter varies
You can optionally specify which x,y pairs you are interested in using lhs and rhs and you can also weight the data if you have a wave containing the standard deviation.
Function chi2generator(fn,ydata,xdata,coefs,whichParam,searchArea, [edata, lhs, rhs])
FUNCREF chi2fitfuntemplate fn
Wave ydata,xdata,coefs //y data, x data, and coefficient wave
variable whichParam, searchArea //which of the parameters to you want to vary, how far from the original value do you want to search (%)
Wave edata //wave containing standard deviation for the x,y pair
variable lhs, rhs //specify a region of interest in the data using a left hand side and right hand side.
variable originalvalue = coefs[whichparam]
variable range = originalValue * searchArea/100
variable ii
duplicate/o ydata, :theoretical_data, :chi2_data
Wave theoretical_data, chi2_data
make/o/n=200/d chi2_map
setscale/I x, originalvalue - range/2, originalvalue + range/2, chi2_map
if(paramisdefault(lhs))
lhs = 0
if(paramisdefault(rhs))
rhs = numpnts(ydata)
for(ii=0 ; ii < numpnts(chi2_map) ; ii+=1)
coefs[whichparam] = pnt2x(chi2_map, ii)
theoretical_data = fn(coefs, xdata)
chi2_data = (ydata-theoretical_data)^2
if(!paramisdefault(edata))
chi2_data /= edata^2
Wavestats/q/R=[lhs, rhs] chi2_data
chi2_map[ii] = V_avg * V_npnts
coefs[whichparam] = originalvalue
display/K=1 chi2_map
killwaves/z theoretical_data, chi2_data
Function chi2fitfuntemplate(w, x)
Wave w
variable x
