    Calculate the width of a tab in points
/// Calculate the width of a tab in points /// /// Result should be entered into Procedure->Document Settings->Default Tab Width /// Remember to select "Points" from the units menu in the same dialog. Function PrintTabWidthInPoints() string fontName = "Anonymous Pro" variable fontSize = 11 variable tabWidth = 4 print FontSizeStringWidth(fontName, fontSize, 0, " ") * tabwidth End
