Hessian matrix estimator
#pragma rtGlobals=3		// Use modern global access method and strict wave access.
//See the following link for central difference problems
//http://www.holoborodko.com/pavel/numerical-methods/numerical-derivative/central-differences/
//the following link says why an EPS of 1e-5 should be used. Basically, if the accuracy for the central difference algorithm is A, then the step size, H, should be A^0.3333.
//Thus, if you calculate in DP, the accuracy is on the order of 1e-15.  The cube root of 1e-15 is 1e-5.
//http://scicomp.stackexchange.com/questions/1875/adaptive-h-for-gradient-estimation
CONSTANT EPS = 1e-5
Function Hessian(fun, vec, oi)
	//this function calculates the second order mixed derivatives of the scalar function fun, around the locus values contained in the vec array
	//Function   fun(vec, oi)
	//		Wave vec
	// 		struct otherInfo, &oi
	//		//do some calculation
	//		return val
	// End
	// vec is an array that specifies the locus around which the derivative matrix is to be estimated
	// oi is a structure containing other information to pass to the fun function. You can alter this structure to make sense for your function.
	// One of it main uses is in estimating the Hessian matrix for a least squares problem (the inverse of which gives the covariance matrix).
        //If you use this to calculate the covariance matrix then you have to follow these steps:
        // 1) divide Hessian by 2.
        // 2) Take the matrix inverse
        // 3) Multiply by chi2/(number of fitted points - number of fitted parameters)
	Funcref energy, fun
	Wave vec
	Struct otherinfo &oi
	variable ii, jj, nvec, t0, t1, t2, t3
	nvec = numpnts(vec)
	make/n=(nvec, nvec)/d/o M_hessian
	duplicate/free vec, scale, freevec, normal
	redimension/d scale, freevec, normal
	scale = 1/vec
	normal = 1
	for(ii = 0 ; ii < nvec ; ii += 1)
		for(jj = ii ; jj < nvec ; jj+=1)
			normal = 1
			if(ii == jj)
				normal[ii] = 1 - 2 * EPS
				freevec = normal/scale
				t0 = fun(freevec, oi)
				normal[ii] = 1 - EPS
				freevec = normal /scale
				t1 = fun(freevec, oi)
				normal[ii] = 1
				t2 = fun(freevec, oi)
				normal[ii] = 1 + EPS
				t3 = fun(freevec, oi)
				normal[ii] = 1 + 2 * EPS
				t4 = fun(freevec, oi)
				M_Hessian[ii][jj] = (-t0 + 16 * t1 - 30 * t2 + 16 * t3 - t4) / 12/EPS/EPS*scale[ii]*scale[ii]
				//f -1,-1
				normal[ii] = 1 * (1 - EPS)
				normal[jj] = 1 * (1 - EPS)
				freevec = normal / scale
				//f +1,+1
				normal[ii] = 1 * (1 + EPS)
				normal[jj] = 1 * (1 + EPS)
				//f +1,-1
				//f -1,+1
				M_hessian[ii][jj] = (t0 + t1 - t2 - t3)/4/EPS/EPS*scale[ii]*scale[jj]
				M_hessian[jj][ii] = M_hessian[ii][jj]
				// the following is a higher order calculation, which is more expensive, but may be worth while.
				//				//f 1,-2
				//				normal[ii] = 1 + EPS
				//				normal[jj] = 1 - 2 * EPS
				//				freevec = normal / scale
				//				t0 = fun(freevec, oi)
				//				//f +2, -1
				//				normal[ii] = 1 + 2 *  EPS
				//				normal[jj] = 1- EPS
				//				t1 = fun(freevec, oi)
				//				//f -2,+1
				//				normal[ii] = 1 - 2 *  EPS
				//				normal[jj] = 1 + EPS
				//				t2 = fun(freevec, oi)
				//				//f -1,+1
				//				normal[ii] = 1 -   EPS
				//				normal[jj] = 1 + 2 *  EPS
				//				t3 = fun(freevec, oi)
				//				M_hessian[ii][jj] = -63 * (t0 + t1 + t2 + t3)
				//				//f -1,-2
				//				//f -2, -1
				//				//f +1,+2
				//				normal[jj] = 1 + 2* EPS
				//				//f+2,+1
				//				M_hessian[ii][jj] += 63 * (t0 + t1 + t2 + t3)
				//				//f 2,-2
				//				//f -2, 2
				//				//f -2,-2
				//				normal[ii] = 1 - 2*  EPS
				//				normal[jj] = 1 - 2* EPS
				//				//f2,2
				//				normal[jj] = 1 +2*  EPS
				//				M_hessian[ii][jj] += 44 * (t0 + t1 - t2 - t3)
				//				//f -1,-1
				//				normal[ii] = 1 -1 *  EPS
				//				normal[jj] = 1 - 1 * EPS
				//				//f 1,1
				//				//f 1,-1
				//				normal[jj] = 1 -  EPS
				//				//f-1,1
				//				normal[jj] = 1 +1*  EPS
				//				M_hessian[ii][jj] += 74 * (t0 + t1 - t2 - t3)
				//				M_hessian[ii][jj] = M_hessian[ii][jj]/600/EPS/EPS*scale[ii]*scale[jj]
				//				M_hessian[jj][ii] = M_hessian[ii][jj]
Function energy(vec, oi)
	Wave vec
Structure otherinfo
Endstructure
Function rosen(w, oi)
	Wave w
	return (1-w[0])^2 + 105 * (w[1] - w[0]^2)^2
Function test(w)
	Wave w
	Struct otherinfo pop
	Hessian(rosen, w, pop)
        //should give
        //M_hessian[0][0]= {842,-420}
        //M_hessian[0][1]= {-420,210}
Andy ...
Rather than hard-commenting out the higher order, perhaps this change would be useful ...
Function Hessian(fun, vec, oi, [ho])
     variable ho
     if (ParamIsDefault(ho))
           ho = 0
     if (ho)
         .... do higher order calculation
