Function to Use Relative Window Sizes
// structure to store screen parameters
// values are RELATIVE SIZES
// POINTS: used for /W=() in tables and graphs
// PIXELS: used for /W=() in panels
STRUCTURE ScreenSizeParameters
variable scrwpxl
variable scrhpxl
variable scrwpnt
variable scrhpnt
ENDSTRUCTURE
// initialize the screen sizes
Static Function InitScreenParameters(ScrP)
STRUCT ScreenSizeParameters &ScrP
// get screen pixel sizes
if (cmpstr(IgorInfo(2),"Macintosh")==0)
// MacOS
string IgorStuff=""
variable scr0,scr1,scr2
IgorStuff=IgorInfo(0)
scr0 = strsearch(IgorStuff,"RECT",0)
scr1 = strsearch(IgorStuff,",",scr0+9)
scr2 = strlen(IgorStuff)-2
ScrP.scrwpxl = str2num(IgorStuff[scr0+9,scr1-1])/100
ScrP.scrhpxl = str2num(IgorStuff[scr1+1,scr2])/100
// WinXX (must maximize the frame)
MoveWindow/F 2, 2, 2, 2
GetWindow kwFrameInner wsizeDC
ScrP.scrwpxl = (v_right-v_left)/100
ScrP.scrhpxl = (v_bottom-v_top)/100
// set screen point sizes
ScrP.scrwpnt = ScrP.scrwpxl*72/ScreenResolution
ScrP.scrhpnt = ScrP.scrhpxl*72/ScreenResolution
// EXAMPLE USEAGE
// Show Examples displays a graph and panel at 60%x40% of screen
Function ShowExamples()
// define the screen parameter structure
STRUCT ScreenSizeParameters ScrP
// initialize it
// show a graph window at 60% x 40% of screen
display/W=(0,0,60*ScrP.scrwpnt,40*ScrP.scrhpnt) as "60 x 40 Graph"
// show a table window at 60% x 40% of screen
edit/W=(0,0,60*ScrP.scrwpnt,40*ScrP.scrhpnt) as "60 x 40 Table"
// show a panel at 60% x 40% of screen
NewPanel/W=(0,0,60*ScrP.scrwpxl,40*ScrP.scrhpxl) as "60 x 40 Panel"
